Dead no fuel 1/4 tank on guage - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-25-2013, 12:12 PM Thread Starter
I have a 2004 f 250 3/4 ton ext cab . the truck died going down the road. I pulled the upper fuel filter out listened for the fuel pump to run sounded fine but the fuel filter would not fill (i pushed down on the center check also) fuel pump? sump screen? anything else
powerstrokephil is offline
post #2 of 5 Old 08-25-2013, 12:24 PM
drivininidaho's Avatar
Quoted: 67 Post(s)
welcome phil... have you tried putting a little fuel in the bowl and seeing if it would start?
Lyndel
'04 F25 SD CCSB
studded, and having some issues.....
drivininidaho is offline
post #3 of 5 Old 08-25-2013, 01:19 PM
ngaraiderman's Avatar
I read where the shower head pick-up in the tank sometimes breaks off. may want to check that out. the black thing on the left
ngaraiderman is offline
post #4 of 5 Old 08-25-2013, 06:49 PM Thread Starter
thanks for the info going to try that thanks
post #5 of 5 Old 09-10-2013, 02:55 AM
That and there are two filters inside the white piece above the pickup. The tank lining can degrade and chips can clog the filters.
96 F-250 XLT 7.3l Crew Cab 4X2 5-spd
jfwatson is offline
