Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
  #11 (permalink)
Old 05-20-2008, 06:19 PM
RobW RobW is offline
Since you couldn't find the leak, did you pull the dipstick to see with certainty that fuel wasn't in your oil? If that happened, you'll have a really clean internal setup, and prolly a wasted set of bearings. An internal leak could be catastrophic in short order. I dount that's your problem so far... But you may also check your coolant reservoir to be sure nothing else is in that. Sometimes a bad seal can cause oil to get into the coolant. I suspect that would be caused at the turbo.
  #12 (permalink)
Old 05-20-2008, 07:26 PM
SMKSTAX SMKSTAX is offline
KCR DIRECTOR
Originally Posted by wrenchbreaker View Post
it's an auto
Well there goes my thought. If it was a 5 speed i was going to say the grinding was your dual mass flywheel. Oh well.
  #13 (permalink)
Old 05-20-2008, 07:28 PM
wrenchbreaker wrenchbreaker is offline
I'm not sure what fuel in the oil would look like...but all I can say is that it looked like clean oil. I do, and have had a few oil leaks for a few years- the rear main seal, oil pan (from salt) and the turbo tends to get oily on the housing. The motor has about 144 k miles on it, was replaced several years ago at the dealer w/ about 60k on it, they installed a new long block at that time. I will check the coolant for oil...
  #14 (permalink)
Old 05-20-2008, 07:50 PM
Well, I checked the coolant reservoir, looks like it could use a good flushing, some crap on the bottom and kinda dirty green- but I'm not sure that I would call it oily...the grime was brown off the bottom, rubbed it in my hand then wiped it off and no oil residue left behind...if that made any sense?
Question: If I were to change the oil, should I find some metal in it, if I did loose the bearings?
  #15 (permalink)
Old 05-20-2008, 08:21 PM
Nope, no coolant system leak based on those findings. I mean, unless you're blind!
Was the oil recently changed? If not, maybe it looks clean because it's "watered down" with diesel fuel. I kinda doubt it. If it's within the usual level on the dipstick, you're alright there too.
Maybe check your flexplate for tightness. That's not common, but it recently happened to someone else I know. Grinding noise would come and go, never lasting long. Turned out to be loose... About 10 minutes and he was good to go. He took it to a local dealer, who lied to him, then directly to a transmission shop, who dianosed and repaired it promptly... And for free.
  #16 (permalink)
Old 05-20-2008, 08:23 PM
You'd prolly get pieces of metal if the bearings are bad... But you may see some anyway, but extremely small.
  #17 (permalink)
Old 05-20-2008, 08:36 PM
Yea, this is a new grind just happened today, doesn't last more than a second or two. that's always the problem, it seems like unrelated things happen at the same time. Now I'm feeling dumb...what's the flex plate and where is it?
Don't know if it's worth also mentioning but, last month my trans was shifting erratic w/ the OD light flashing. I changed the speed sensor in the rear diff. and the problem went away...and I had just replaced it last fall for the first time. some things make no sense...
  #18 (permalink)
Old 05-20-2008, 08:45 PM
Flexplate = flywheel, but is the word used in automatic applications in standard vehicles. Bolts to the crank between the engine and torque converter. Funny though, the other guy I know asked the very same question.... So you're hardly alone.
  #19 (permalink)
Old 05-20-2008, 08:53 PM
OK, so at least I know were not talking about a new space program, lol. I'll look into that tomarrow...
Thank's to all - Frank
