2000 7.3 shuts off - Ford Powerstroke Diesel Forum
post #1 of 9 Old 05-19-2008, 05:04 PM Thread Starter
2000 7.3 shuts off
Alright guys I need some help with my truck, im gettin really pissed off about it.
A couple of months ago my truck kept turning off while I was driving, so I took it to the dealership and had the cam sensor replaced. Everything was fine until about a week and a half ago. When I am driving, it seems like my engine will turn off and turn back on a split second later, it just kind of stalls i guess. Then when i am coming to a stop or am going really slow it will just turn off completely.
I noticed it started happening after I put fuel injector cleaner in it, so someone told me to replace the fuel filter. I did that and it just made my engine turn off more often.
Someone please give me suggestions on what I should do. My truck is giving me a headache
dallascwbyfn is offline
post #2 of 9 Old 05-19-2008, 05:30 PM
Thats Mr. Oil Leak.....
MrJohnWayne's Avatar
Quoted: 5 Post(s)
Still sounds like a Cam sensor. Sounds like it to me. Could of been a defective sensor from ford..
John Wayne
Owner and Operator of the
REDNECK VALDEZ
You can find me on
MrJohnWayne is offline
post #3 of 9 Old 05-19-2008, 05:35 PM
Cynic
Dirk's Avatar
Are you running a tuner chip?
Best Car & Motorcycle Insurance | Auto/Moto Protection Today | FREE Trade-In Quote
Voluntary Banishment: Knowing when to leave.
Total Diesel Performance\Unlimited Diesel Performance\Diesel Innovations\BTS\Terminator Engineering\Swamp's Diesel Performance\Black Widow Diesel\Calvert Racing
Dirk is offline
post #4 of 9 Old 05-19-2008, 06:30 PM
drstephennix's Avatar
Quoted: 2 Post(s)
Send a message via Yahoo to drstephennix
Yeah, its possible they put a bad one in or a wiring harness shorting out the sensor maybe. That happened with mine. Bad harness kept shorting out the IPR sensor.
2011 F-350 CCSB KR 4x4
35" Hancook AT's
AFE CAI
6.7 Scorpion
197k miles
Back in the diesel game!
In the words of David Crockett, "You may all go to hell. I will go to Texas!" spoken in the halls of congress; circa 1830's
drstephennix is offline
post #5 of 9 Old 05-20-2008, 03:49 AM
Mine still shuts off. It's going to Ford today to get a cam sensor. What's weird is that dies more when it rains.
maxxgraphix is offline
post #6 of 9 Old 05-20-2008, 04:53 AM
Hoytster's Avatar
Quoted: 14 Post(s)
I had the same problem. Check the two sensor connections that are located on the backside of the fuel bowl. There is one that has a small metal clip that flips over and keeps the connection tight against the sensor. Excuse my ignorance but I forget what that sensor is called, the other connection is for the fuel heater I beleive.
What was happening with mine was that connector was loose because the metal clip wasn't holding it in place. Under normal driving it would just shut off for no reason, or would spit and sputter and then drive fine. Finally it shut off completely and wouldn't start. A few days later (and a few parts later) I noticed that particular connection loose, plugged it back in and she started right up and has been fine ever since. If I unplug it, she dies.
Hopefully a tech will pop in and clear things up.
Just my
2011 6.7 Crew Cab 4x4
Hoytster is offline
post #7 of 9 Old 05-20-2008, 05:17 AM
Quoted: 5 Post(s)
Hoyster, the plug with the metal clip is the IPR
John Wayne
REDNECK VALDEZ
You can find me on
post #8 of 9 Old 05-20-2008, 03:55 PM
Hoytster's Avatar
Quoted: 14 Post(s)
Thanks! I figured it was just didn't want to give mis-information.
Hoytster is offline
post #9 of 9 Old 05-22-2008, 06:46 PM Thread Starter
Thanks hoyster I got in there and made sure the connections were nice and tight so I will see how it runs tomorrow.
if it does happen to be the cam sensor again, is there anyone that sells an aftermarket one that way I don't have to replace it with the cruddy Ford one?
