I need professional opinion from Video of acceptable blowby from 7.3 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-19-2013, 12:53 PM Thread Starter
I have a creampuff 1997 Ford. You know, the kinds with 110,000 miles and has always been garaged / never used for anything. Anyway, I notice i have alot of blowby coming from the oil fill cap and i am very concerned. I please ask anyone here for their opinions on whether this amount of blowby is acceptable or not? I have a 45 second video right here for all of you to see.
tommyjon is offline
post #2 of 7 Old 08-19-2013, 01:02 PM
blue99stroker's Avatar
Quoted: 260 Post(s)
every 7.3 has blow by.
if your trying to see if its bad, take the cap and put it upside down over the hole. if it gets blown off then you have too much blow by. if it just slowly moves off then your fine.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 7 Old 08-19-2013, 02:29 PM Thread Starter
Is this amount as seen in the video excessive to any of you with experience with this type of engine? Any feedback would be appreciated, I am being told this is above normal and my rings could be failing or my headgasket is blown.
tommyjon is offline
post #4 of 7 Old 08-19-2013, 03:46 PM
Quoted: 3 Post(s)
looks like mine.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #5 of 7 Old 08-19-2013, 03:54 PM Thread Starter
Compare
@ campbellflage...Is your 7.3 healthy? How many miles on it?
tommyjon is offline
post #6 of 7 Old 08-19-2013, 04:05 PM
Quoted: 3 Post(s)
210k on mine, runs perfect
2000 DRW CC 7.3
post #7 of 7 Old 08-19-2013, 04:06 PM
Quoted: 3 Post(s)
try the lid test as stated by the other member, flip it over and set it on there. If it vibrates around and falls off its ok, but if it gets blown off then its probably a little excessive.
2000 DRW CC 7.3
Tags
7.3 blowby , blowby , potential engine failure
