Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
  #11 (permalink)
Old 05-14-2008, 09:57 AM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
the big die grinder tool works for the lines on the oil rail , ive even barely sharpened the edge a little to help get in there , as far as the a/c get you 3 cans ,and charge it back that way , dont use contaminated freon
  #12 (permalink)
Old 05-14-2008, 11:14 AM
03ccf350 03ccf350 is offline
sorry guys. i didnt make that clear. i want to get the old stuff out of the system to disconnect the lines.
  #13 (permalink)
Old 05-14-2008, 10:11 PM
Bobby Tannehill Bobby Tannehill is offline
A vac pump doesn't matter like dirk said, a recovery machine does matter! diff pressures and NO NO NO you can not mix them to go back in. out is fine but if your turning it in they will charge you more for the blend. If you are pulling it out, get the kit for like 20 bucks undo the connector and change the orifice screen while you have it empty of the refrigerant. just use needle nose to slide it out and put back the same color orifice. The cork (seals i think they are) come apart and make you air not work at idle. makes a huge diff and could save your compressor. you can buy all the stuff to charge it yourself at any part store. like 100 bucks its pretty fool proof. I've done 5 trucks for friends and worked great on all. I know I'm off topic now but thought id throw that in there. if its like mine its four cans it says on the label by the radiator. just do the math.
