7.3 bottom ends - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-14-2013, 06:53 AM Thread Starter
7.3 bottom ends
I lost the bottom end in my 2001 F350 7.3. Some where I've read that all 7.3 engines are the same in the short block and the heads, intakes, etc is all that's different but will swap over.. Does anyone know if that's true. Our local Pull A Part just got 8 7.3 ambulances I'm all with 130k to 150 on them and i can pick up an entire engine for $700.
Any help would be great. I'd really like to have my truck back on the road asap..
DOMINANCE is offline
post #2 of 10 Old 08-14-2013, 07:32 AM
PSDTV21's Avatar
Yep should be the same. 700 is a good price I think. What do you need? I have parts...
-Tyler
1994.5
Efuel, Valair 500hp, D60, Hydra w/PHP tunes
PSDTV21 is offline
post #3 of 10 Old 08-14-2013, 07:41 AM
Quoted: 764 Post(s)
Since you have your pick try to get a forged rod one.
Corey@CNCFAB is offline
post #4 of 10 Old 08-14-2013, 06:24 PM Thread Starter
Thanks for the feed back so quick..
Not sure till I pull my engine out. But they are going to crush all the trucks next week so Ill jump on grabbing one this weekend.
I know my Intake side of turbo broke and I got trash in at least two cylinders. No real compression on them and pressure in the pan. I'm hoping both heads are good if so I have a 90mm turbo off a bus and my buddies who drift said they'd help with a custom set up with a blow off valve. I already ordered ARP studs and about to order some bigger injectors. Main thing holding me up has been a solid bottom end.
Anybody got any good direction on head gaskets and any head work to do while it's all out and apart. I'm planing on doing front and rear seals and a few other things that will be easier while engine is out. Any advice or tips are greatly appreciated.
Also heard that a 6.0 trans is a direct bolt in. Stronger and I know has one more gear. Any truth to that rumor I actually have one sitting in my shed..
Once again thanks
post #5 of 10 Old 08-14-2013, 06:31 PM
Quoted: 764 Post(s)
Use ford OEM head gaskets. No a 5r110 will not bolt right up. But a 6.0l oil cooler will bolt right up.
By the time you buy all the stuff you need to do a swap and programming your better off with a BTS or JW transmission.
post #6 of 10 Old 08-15-2013, 06:20 PM Thread Starter
Thanks again going to pull an engine sat. Is there anything externally or in the block number or a stamp that will say if it has forged or cast rods. Not sure they are gonna let me pull oil pans just to check.. I already grabbed an oil cooler and did the swap a few years back..
post #7 of 10 Old 08-16-2013, 06:24 AM
PSDTV21's Avatar
Not sure if there is certain casting numbers that denote forged rods. My blocks have a 3 on the 94 and a 2 on the 97.
-Tyler
1994.5
PSDTV21 is offline
post #8 of 10 Old 08-16-2013, 07:01 AM
Quoted: 764 Post(s)
Supposedly there is, but many have done the SN check and found out otherwise. You never know if the bottom was redone with/without forged rods. Best is to check from block inspection port n flash light. You don't have to drop the pan. From what I was told anyway.
post #9 of 10 Old 09-04-2013, 03:06 PM Thread Starter
Thanks for the help I ended up with a 00 Powerstroke with 168k started up and ran after 4-5 turns. Had all the service records in the cab, oil was changed every 2500-3k miles everything looked clean so I'm gonna start pulling my engine next week and swapping out parts and doing some up grades( head gaskets, ARP studs, injectors,Stealth pump,etc).
Are the 2001 heads on my engine better/worse or is it a must change? Haven't set them side by side just trying to figure out what I have to change and which parts are better from either newer or older engine..
post #10 of 10 Old 09-04-2013, 03:50 PM
PSDTV21's Avatar
Heads are the same for both. Take your pick. If youre going to add all those up grades make sure you have forged rods or youll be replacing them as said earlier
Sent from AutoGuide.com App
-Tyler
1994.5
PSDTV21 is offline
