Engine has a lopy idle in park and neutral - Ford Powerstroke Diesel Forum
post #1 of 2 Old 08-13-2013, 03:41 PM Thread Starter
I just bought a 1995 f-350 7.3 Powerstroke with 265kmiles. When it's in park and neutral the engine has a really unnaturally lopy idle. And by that I mean the rpm's will fluctuate sporadically between I'm guessing 700-900 rpm. This shakes the truck when in park. It also has a check engine light code, and if somebody's here knows how to read it that would be great as well. However as soon as you rev the motor or put it in gear the motor runs just fine but the check engine light stays on.
Smlarson is offline
post #2 of 2 Old 08-16-2013, 01:25 AM
The RPMs seem a little too high for idle, it should idle around 550 rpms. Check the valve cover gasket wire harness. If the glowplugs havent been replaced in a long time, they pull too much current and cause the electrical connection to the wire harness to melt, which can make an injector cut out, causing a bad idle.
USNavyPowerstroke is offline
