consistant miss - Ford Powerstroke Diesel Forum
post #1 of 2 Old 08-10-2013, 08:57 AM Thread Starter
consistant miss
hey, new member to this forum...I have a 2005 6.0l and it has a consistant miss....using AE I found code p0275 cyl. #5 contribution balance fault, performed injector cut out test and it definitely was #5 that was dead, cleared code and ran again... same code came back. re/re new #5 injector and let it run until the air was worked out...still missing!! WTF!! gonna pin out wiring to ficm.....but should be low/high circuit codes if wiring was the issue, no?
sour dalton is offline
post #2 of 2 Old 08-10-2013, 08:58 AM Thread Starter
P.S....no smoke, no CEL
