HPOP Gear Bolt fell out into engine... - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-05-2013, 11:49 AM Thread Starter
Hi guys, I have a late build '04 F350 with a 6.0. I just changed the HPOP a couple days ago and on a test drive it died 2-3 miles from home. Towed it home, determined I had no high oil pressure again, and tore it back apart. I found that the bolt that holds the drive gear fell out. My question is... What are the odds it's sitting in the oil pan? I'm not too sure of the internals, but that would make sense to me. Also wondering if I could get lucky and find it with a magnet from the top.
ckostac is offline
post #2 of 6 Old 08-05-2013, 12:11 PM
Quoted: 6 Post(s)
There is a spot in the rear cover that it will most likely fall into. You should be able to fish it out from the top.
Now the real question is why did it fall out?... Did you buy an OE pump?
The only time I have seen this happen is when the camshaft had tons of play in the block and the cam was floating. Im not sure why it caused the bolt to fall out, but I put 2 pumps in the same truck with the same results. Tore the motor down and the cam was wasted.
05 Extended Cab FX4
SCT w/ Gearhead Tunes
Ble-Blah mod...
Edge Insight CTS w/EGT
PHP Tuned FICM-Hercules
a2elvis is offline
post #3 of 6 Old 08-05-2013, 12:43 PM Thread Starter
It is a Borg Warner pump from O'Reillys. Also, I'm sure it is a rebuild, not a new pump. I went with that one as it had a lifetime warranty. The other one they had cost way more, and only had a one year warranty. Anyway, I'd like to think that it was just poor workmanship on their part, and never got torqued down properly. I don't even want to think about cam issues! Oh well, I guess it's time to go fishing, and not the fun kind!
For what it's worth, when the truck is running, it runs great. I run 5w40 Rotella T6 Synthetic, I use Power Service at every fill up, and am running CAT ELC coolant. It has about 160,000 mi, but I have only had it for the last 20-30 thousand, so who knows how it was taken care of before me.
Actually, the before me is what started this whole mess. Green Antifreeze. Oil filter plugged leading to EGR failure. I welded plugs into both ends of the EGR cooler, cleaned out the intake, replaced EGR cooler. Flushed out old coolant with CAT Cleaner and several rounds of distilled water, then filled with about 60/40 CAT ELC. That was a month and a half ago. The gasket under the oil cooler started to disintegrate already(also from Oriellys, really starting to question their stuff), and caused the HPOP issues. This time I replaced HPOP and IPR valve(IPR valve did come from Ford) just to be on the safe side. Thought I would be good for a while. Wrong!
ckostac is offline
post #4 of 6 Old 08-05-2013, 12:45 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
OEM FTW!
2000-7.3L is offline
post #5 of 6 Old 08-06-2013, 11:20 AM Thread Starter
Just an update - I bought one of those inspection cameras for just under $100. Worked like a charm. Took a couple minutes, but I found the bolt. Then I put on the magnet attachment, and about a minute later I had it out. Totally worth it! Plus, I didn't waste my time pulling the oil pan for nothing. Also, I returned the HPOP back to Orielly's and went and ordered one from Ford. Of course it cost a couple hundred more, but hopefully it will be worth it.
ckostac is offline
post #6 of 6 Old 08-09-2013, 06:02 PM Thread Starter
She's all back together and running again. Hope she stays that way for a while this time!
ckostac is offline
