NEGATIVE WIRE TO STARTER MIA - Ford Powerstroke Diesel Forum
post #1 of 8 Old 08-05-2013, 12:14 PM Thread Starter
taskforcefreddy's Avatar
This is absolutely ridiculous. Had to change out starter. Got old one out. Installed new one, hooked up positive, go to hook up the negative lead to new starter and it's gone. Like, 100%, cannot track it down, gone. Been looking for 4 hours. Covered completely in grease and dirt. Looked from every angle using inspection, flashlight etc. This is the third time replacing starter... NEVER had an issue in doing this 1 hour process. Where the F*CK could it have gone and where does this line run to so I can back track the line? Thanks for any help.
taskforcefreddy is offline
post #2 of 8 Old 08-05-2013, 05:39 PM
i think that starter does not have a ground wire bolted to it just power wire and signal wire and 3 bolts to mount it ground comes from it being bolted to engine
posreairs2013 is offline
post #3 of 8 Old 08-05-2013, 06:07 PM
kclough's Avatar
Every starter I ever replaced has been a power wire and a remote wire and that's it
kclough is offline
post #4 of 8 Old 08-05-2013, 07:51 PM
ZMANN's Avatar
Quoted: 1343 Post(s)
ya think doing it 3 times before ??
just sayin
We Miss you Ronnie
ZMANN is offline
post #5 of 8 Old 08-05-2013, 07:56 PM
kclough's Avatar
According to the Haynes manual there should be a red wire and a tan/red wire.
kclough is offline
post #6 of 8 Old 08-05-2013, 08:00 PM
spoonfedblue's Avatar
Starter should only have two wires, one large, heavy gauge B+ wire (hot directly from battery), and one smaller signal wire that engages the solenoid (feed from starter relay). There is no negative wire.
ASE Certified Master Tech A1-A9
L1 Advanced Level Specialist
yours
2006 F-250 SCSB 6.0 FX4 Lariat
285/70R17 Nitto Trail Grapplers, Upfitters w/ High Idle, 4" Turbo Back Straight Pipe, AFE 6" Polished Tip, Insight CTS w/ EGT, Blue Spring, IPR Gen 2, CAT ELC, DieselSite Coolant Filter, Cloud Rider Cold Front
spoonfedblue is offline
post #7 of 8 Old 08-05-2013, 08:00 PM
heres your sign...lol good luck finding it.
2008 F450 KING RANCH
DELETED
H&S MINI
ARP HEAD STUDS
RUDY'S HD UP PIPES
S&B CAI
ALRADCO RADIATOR
OEM PISTON W/HOLE FOR PAPER WEIGHT
5R110W WITH BILLET GOODIES AND AERMET SHAFT
4 CAR WEDGE TRAILER
ALL WORK DONE BY RUDY'S
87K599 is offline
post #8 of 8 Old 08-06-2013, 01:53 AM Thread Starter
It has both a positive and a negative plus the relay. Tow truck came and guy asked what was wrong. Explained everything and he was like, no way. He has a 6 liter and replaced the starter 4 months ago. He was under the truck for half an hour til he got disgusted and threw in the towel. This is absolute bullsh*t.
Sent from AutoGuide.com App
