grey smoke bellowing from exhaust! and no power! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-05-2013, 10:27 AM Thread Starter
i just replaced the oil cooler and did an EGR delete kit for my 2003 F-350 6.0L and now i have little to no power and when i try to step on it grey smoke bellows from the exhaust. my EDGE insight has picked up 3 codes:
P0098: Intake air temperature sensor 2 circuit high input
P0603: Internal control module keep alive memory error
P1000: on-board diagnostic OBD systems reediness test not complete
PLease help i'm suppose to commute back my job 3hrs away in 2 hours from now!!!
2003 F-350 6.0L CC Lariat
2011 F-150 5.0L CC XLT
179welder is offline
post #2 of 6 Old 08-05-2013, 10:30 AM
International Threat
Marty's Avatar
Did you plug the mass air flow sensor back in on the intake?
Did your EGR rupture before doing the EGR delete? If so... could have residual coolant in the exhaust.
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #3 of 6 Old 08-05-2013, 10:36 AM Thread Starter
yes the mass air flow is plugged in, i triple checked that all connections are connected. the EGR, to my knowledge, was working just fine but i decided to delete it while i was in changing the oil cooler since i live in an area that has no emissions at all
post #4 of 6 Old 08-05-2013, 11:03 AM Thread Starter
i'm also noticing a hissing noise coming from the engine sounds like its coming from the passenger side towards the firewall, ideas?
post #5 of 6 Old 08-05-2013, 11:16 AM
Marty's Avatar
Up pipe clamp where it connects to the turbo.
Also is the MAP sensor 1/4" line plugged in?
2001 F250
11.62 @ 115.79
Elkton, Maryland
Marty is offline
post #6 of 6 Old 08-05-2013, 05:31 PM
hissing noise sounds like a ripped intercooler pipe sometimes hard to pin point that will deff give u no power
posreairs2013 is offline
