Mechanic stumped...now I'm stranded - Ford Powerstroke Diesel Forum
post #1 of 17 Old 08-02-2013, 04:59 PM Thread Starter
Hello Gentlemen, I'm hoping you have some insight into my issue. Three mths ago my 2001 f250 7.3l with 130k started getting harder to start. Like the batteries were slowly draining from not being recharged by the alt. So, I changed both batteries and that helped for a week. Finally, I reLized the bolt that connects the alt to a fat wire was severely corroded so we put a new connector on. But the problem still persists. My mech hooked up his volt meter and he says everything looks good with the elec system. So it's still harder and harder to start till today it died and won't kick. Tried jumping it but nothing. So... Could it be the starter? Or a subtly bad alt?
Any clue?
TxPlatinum is offline
post #2 of 17 Old 08-02-2013, 05:05 PM
usnavyad's Avatar
Feedback Score: 3 reviews
What's it sound like when u turn the key
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #3 of 17 Old 08-02-2013, 05:09 PM Thread Starter
Turns over normally. Just real slow. But at different times it is faster. Sometimes it won't fire, I turn it off, then turn the key and it turns over faster. I don't get it.
Now it's dead.
No mas juice.
post #4 of 17 Old 08-02-2013, 05:40 PM
Fantom's Avatar
Quoted: 11 Post(s)
Feedback Score: 4 reviews
Did you try testing with a voltmeter? Let the truck run, put a voltmeter on one of the batteries. If the alt is good you should be around 14 volts
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #5 of 17 Old 08-02-2013, 06:57 PM
sounds like a voltage drop. and if u replaced a connector on a corroded wire mosed likely its in that cable and if the corrosion worked its way into cable. only way to figure out is to do voltage drop test.
posreairs2013 is offline
post #6 of 17 Old 08-02-2013, 07:04 PM
c69ss396's Avatar
If your Batteries tested good then my guess would be a bad starter.
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #7 of 17 Old 08-02-2013, 07:05 PM Thread Starter
I have it hooked up to a battery charger and it won't even turn over now. It just clicks once and that's it. Shows 65 percent charged.
post #8 of 17 Old 08-02-2013, 08:06 PM
Fantom's Avatar
Quoted: 11 Post(s)
Glow plug relay staying on and drawing current?
John
100,000 Miles
Fantom is offline
post #9 of 17 Old 08-02-2013, 08:23 PM
Voltage drop test very simple and free trowing parts not cheap.
post #10 of 17 Old 08-02-2013, 08:23 PM
MahdeyS's Avatar
can the engine rotate easy by hand? Lets start with the basics...
01 Excursion 4x4 PSD
MahdeyS is offline
