Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 10-12-2006, 12:40 PM
michande04 michande04 is offline
Fuel leak by the fuel filter????
I have a 97 powerstroke with a 96 body style and I have found a fuel leak on what seems to be a sensor. If a person is at the front of the engine looking at the fuel filter it is a piece that it to the right of the filter and it has a single wire running to it. It is coming out at a steady drip. I would like to know what this piece is and how to change it out. Hopefully I am not being to vague. IF more accurate information is needed let me know and I will do my best to describe it better.
Thanks for any help at all.
Mike
Old 10-12-2006, 12:49 PM
Clay Henry Clay Henry is offline
Sooner Powerstroker Mod
Mike
Welcome to the Forum Mike. I"ll let one of our 7.3 gurus answer your question! Someone should see this soon and give you some info.
Old 10-12-2006, 06:06 PM
toobadq toobadq is offline
Pull the sensor and put a pipe plug in the hole. I have done many and never had a problem.
Old 11-29-2006, 09:21 PM
SuicideAxles SuicideAxles is offline
Send a message via AIM to SuicideAxles Send a message via Yahoo to SuicideAxles
Had that happen to my '96 2 weeks ago. It's the Water In Fuel Sensor (WIF) costs about $50 at the dealer. You can temporarily fix it by removing the sensor and unplugging the wire, wrapping an 1/8" NPT pipe plug with teflon tape and install it into the hole. The WIF light on the dash won't come on if you actually have water in the fuel because, durrrrrr, there's no sensor. Leave it with the plug in it, or shell out the $50 and replace it.
The Ford part number I have for the WIF Sensor is: E8TZ9J308A
