7.3 leaking everywhere - Ford Powerstroke Diesel Forum
Old 04-25-2008, 01:52 PM
i was going down the road in my 94.5 7.3 powerstroke and it started slowing down like it wasnt getting any diesel. i parked her and thought the svo i ran just clogged my filter. when i looked under i saw diesel pouring out from between the tranny and motor. now when i try to start it the valley just gets diesel in it. and the filter housing isnt filling.
Old 04-25-2008, 02:06 PM
bump..........
Old 04-25-2008, 02:15 PM
Desert Shield/Storm Vet
Your going to have to track down the leak
Old 04-25-2008, 02:16 PM
i pulled my y pipe already and poked around i can find it exactly but im thinkin it is under my filter housing or very close but its definately behind or under the filter housing
Old 04-25-2008, 02:23 PM
Pull your fuel filter and see if your housing has rotted out.
Old 04-25-2008, 02:24 PM
i pulled it how would i be able to tell
Old 04-25-2008, 02:25 PM
COLLEGE KID
Send a message via AIM to lifewitlooie
To hunt down my leak I had someone turn the truck on while i was looking into the engine bay. then have ur head poking around in there to see where it is spewing from
Old 04-25-2008, 02:27 PM
Is the fuel bowl holding fuel? Drain the bowl and physically check it out by looking and you could use the screwdriver trick to poke down in and see if you have and soft spots from corroision.
Old 04-25-2008, 02:28 PM
well it doesnt spew really it must be really small but after a while the valley will fill up and run down the back of the motor. the only way to keep her running is to spray ether in it
Old 04-25-2008, 05:33 PM
ok its the fuel pump i removed the filter housing and now am taking off the turbo to remove the fuel pump. the pump was spewing out i cant tell from where
