speed related stall please help! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-26-2013, 01:09 PM Thread Starter
Got to drive this truck from KY to WI. When I get to 32 mph the truck dies as if the key was turned off and will not fire until the speed comes down. I have replaced uvch , IPR, ICP and fuel filter. No check engine line or anything. Any thoughts? Any help is Appreciated.
Edit: early 99 7.3 6 speed
1chancew is offline
post #2 of 4 Old 07-26-2013, 02:36 PM
Quoted: 184 Post(s)
Feedback Score: 3 reviews
Fuel Delivery?
So, it's maybe rpm and not mph that's the issue. Change the Fuel Filter
NoRalPh is online now
post #3 of 4 Old 07-26-2013, 05:26 PM
just because check engine light is not on does not mean there is no active codes i would put a scanner on it. could be crank sensor issue
posreairs2013 is offline
post #4 of 4 Old 07-27-2013, 12:46 PM Thread Starter
It isn't rpm related as it will shut down at idle if you are going down hill clutch in. As long as you hit 32. It's coming and going, sometime runs like a champ other times it will shut down. Took it to the ford dealer it had a speed sensor cod of some kind. I checked the wires over the diff and someone had spliced them in cheap fashion and taped them together. I replaced the sensor and plug. So for so good, but the behavior is erratic to soon to tell.
1chancew is offline
