Help stuck just south of Cincinnatti - Ford Powerstroke Diesel Forum
post #1 of 16 Old 07-21-2013, 07:44 PM Thread Starter
o.k. newbie here so here goes my intro along with my problem, my name is Darrel, I'm a former auto mechanic, now Millwright for Ford MoCo I have a 2003 f250 w/ a 6.0L it has just under a 100k and to my knowledge is stock, I bought it 2 years ago with 72k on it and it's been running great the only mod I've done is the blue spring, now to the problem...while on vacation this week I went from MI to Gatlinburg TN ran great, then from TN to KY again no problems, on friday morning I got up to drive to see my uncle and the truck was running rough, thought I picked up some bad fuel in TN, met my parents at my uncles and then they followed me about 20 minutes away to my Aunts house. my dad said my truck was smoking, after leaving her house going back to motel, (this is E. KY very hilly) I noticed a lot of black smoke, way more than I had ever seen, stopped at gas station and put some cetane boost injector cleaner in didn't change anything, headed home today and the longer I drove the worse it got went from black smoke to blueish grey to white, coolant level is good, oil level is good, truck stop mechanic says I'm burning oil through my intake, smoke also now seems to be coming from under the hood from behind the tubo, any help as to a place near Florence KY, that can fix this, don't want to pay to have to tow it all the way back to Detroit. thanks, D.
BigD13 is offline
post #2 of 16 Old 07-21-2013, 09:48 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
Maybe the seal on your turbine wheel in your turbo blew out. If you are burning oil I would say at least the seal is gone. Do you have any codes? Welcome to the org. By the way.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #3 of 16 Old 07-22-2013, 04:25 AM Thread Starter
no check engine light, so I'm assuming no codes
BigD13 is offline
post #4 of 16 Old 07-22-2013, 05:20 AM
The check engine light might not come on. Check the top of your turbo and bottom where your oil supply line is and return for oil . Look under your turbo for oil. Is there any oil coming out of your exhaust manifold or is all coming out of the down pipe from your turbo. If you have a leaking turbine seal I do not know if it is safe to drive. You could blow the hole seal and pour oil in your exhaust pipe then you are stuck on the side of the road. Maybe some one with some personal experience will chime in.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #5 of 16 Old 07-22-2013, 07:31 AM
Turbostang500's Avatar
If it is running rough, I would say it is a fuel/injection problem and going to a capable shop to have scanned would be a good idea. It could be any number of things like a FICM, IDM, injector, IPR, fuel pressure, etc.
Lee
2000 F250 PSD SCSB 4X4 418k miles straight pipe gauges 2" leveling kit 315/75r16's
6637 with custom intake pipe. TS Performance 6 position chip!
[/URL]
Please don't confuse my attitude with my personality.. my personality is who I am,my attitude depends on who you are...
Turbostang500 is offline
post #6 of 16 Old 07-22-2013, 07:35 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Still might be bad fuel and you need to change both fuel filters and a drain of the water/ fuel separator... Good luck and
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #7 of 16 Old 07-22-2013, 10:00 AM Thread Starter
there is oil around the turbo can't tell where it's coming from, my Uncle is on his way here with a car hauler so we are gonna try and get it back to Michigan tonight, thanks I'll keep you all posted.
BigD13 is offline
post #8 of 16 Old 07-25-2013, 12:57 AM Thread Starter
got it home
o.k. got her home and thanks to a couple of good friends who one fleets of trucks they turned me on to their mehanic, when he pulled the codes it had 3 differant ones: egr, turbo, and missfire on #7, also said it sounded like I may have a damaged push rod anyways here is a pic of what it looked like going home Monday.
BigD13 is offline
post #9 of 16 Old 07-26-2013, 05:42 PM
take egr valve out of intake most likley its stuck open clean it free it up close valve reinstall and leave it unplugged.and if u have a turbo code the accuator for the vgt could be no good or lot of times carbin build up in turbo stops vanes from moving but start with simple stuff first clean egr. and push rods bent slim chance.
posreairs2013 is offline
post #10 of 16 Old 08-01-2013, 09:52 PM Thread Starter
well here it is a broken injector on the #7 cylinder the other part is somewhere in my engine, not liking where this is going. My mechanic is telling me that the other part has damaged the head and the piston, may need a new motor, this sucks anyone know what a non running 10 yr old truck is going for? I could probably scrap it out but that's a whole lot of work I don't have room or time for.
BigD13 is offline
