Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
  #11 (permalink)
Old 04-24-2008, 09:21 AM
psdexcursion psdexcursion is offline
I would like to run the S&B, but wifey doesnt like the whooosh of the wastegate.....doesnt bother me, but I am not in management, I just work here...lol. I may try an open air setup for a few miles to see if the temps come back down or not.
on second thought, I need 2 intakes, one for wifey and one for me towing....that would be the berries
Joe
  #12 (permalink)
Old 04-24-2008, 09:24 AM
Also, talked to Kevin (@BWD) and he is calling TN to see if there is something else we should be looking at
  #13 (permalink)
Old 04-24-2008, 10:59 AM
!!!PainTrain!!! !!!PainTrain!!! is offline
TED NUGENT FOR PRESIDENT
Good luck and keep us posted!
  #14 (permalink)
Old 04-24-2008, 11:28 AM
lords88 lords88 is offline
By wooshing of the wastegate do you mean the EBPV? If so just put the S&B back on and then unplug the EBPV then you will get the best of both worlds.
  #15 (permalink)
Old 04-24-2008, 11:31 AM
scheidt27 scheidt27 is offline
yea the wastegate makes ZERO noise when it opens, its like a bypass valve in the exhaust housing that the actuator pushes open
  #16 (permalink)
Old 04-24-2008, 01:36 PM
its the loud whooosh sound you get when you let off of the accelerator after being in it. my wife isnt skeered to drive it....lol, just doesnt like the whooosh. I thought the EBPV only worked when it was cold? This is all of the time.
  #17 (permalink)
Old 04-24-2008, 01:52 PM
its just air getting pushed back through the intake. nothing to do with the EBV
  #18 (permalink)
Old 04-24-2008, 02:15 PM
Marty Marty is offline
International Threat
I'm going to be testing a Garrett 38R in place of the TN... just to see if the EGT's drop myself. After that I'll be moving to a larger turbo since I'll be introducing even more fuel...
The TN is GREAT, don't get me wrong... it's an AWESOME towing turbo - ZERO SURGE and when you go from 25-30 psi it slams you in your seat. I can't wait to see what happens when it's pegging 40?
Usually high egts mean a boost leak or exhaust leak.
Culprits = upipes, I/C boots, spider boots...
As for the WHOOSH, that's just air coming back out of the inlet of the turbo... that can be minimized by running a lower power program, installing a sheild or adjust the wastegate to allow less psi.
The EBPV is a totally different item, has nothing to do with that sound... but can cause other sounds, like a "hissing" if it's partially closed at idle or driving around.
  #19 (permalink)
Old 04-24-2008, 06:39 PM
I cant get 25-30psi without the EGT's pegging out....will try and resolve this soon.
  #20 (permalink)
Old 04-24-2008, 06:52 PM
I didn't get passed 30 psi until I put stage 3's in...
prior too... it was closer to 25...
