Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 04-15-2008, 07:03 PM
mdcody mdcody is offline
99 7.3 wont start
Ok i have a 99 7.3 that will not start unless i pop the clutch. The truck cranks over just fine but will not start. The glow plug relay works just fine. If i pop start the truck it fires right up and runs like a champ. I have no clue where to start or what to look for? My guess would be maybe a fuel issue but i don't know how to check it.
Old 04-15-2008, 07:11 PM
FordCowboy FordCowboy is offline
I'm really not sure what that would be but since it works when you pop the clutch I would think your fuel is fine. I would think your starter isn't turning quite enough to start it up or possibly batteries slightly too low to spin it enough. But I'm sure someone will have a better idea for ya. Good luck.
Old 04-15-2008, 07:15 PM
new batteries and it cranks just like my 01 does
Old 04-15-2008, 07:17 PM
bigcountrysg bigcountrysg is online now
Countryboy Mechanic
Could it be the safety switch for the clutch. Kinda like the neutral safety switch for an automatic trans. If that is bad it might crank all day but not fire.
Old 04-15-2008, 07:19 PM
SCUFFY828 SCUFFY828 is offline
FORD MASTER DIESEL TECH
that really makes no since at all, i agree with the weak batteries myself
Old 04-15-2008, 07:26 PM
batteries brand new i thought of that even hooked the truck up to another truck
Old 04-15-2008, 07:28 PM
hooking it to another truck wouldnt make any difference if starter was dragging just enough to keep it from starting , ive seen alot of them that seem like there spinning good but just wasnt quite enough to fire
Old 04-15-2008, 07:29 PM
even with new batteries 800 CCA
Old 04-15-2008, 07:31 PM
cca makes no difference if starter isnt spinning fast enough due to weak starter, or even batterie cable problems, may not be getting but 400 cca if you know what i mean
Old 04-15-2008, 07:32 PM
yea i know what you mean but how do i check
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
