06 Power Stroke won't start after towing trailer - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-15-2013, 06:35 AM Thread Starter
I am new to the forum but know you guys can help me. I have a 2006 F250 6.0 and I am having trouble. I towed my trailer last week with a UTV and a Zero turn mower so not a lot of weight and it ran fine until i turned it off. It would crank fine but would never start. Just by luck I was home and not stranded. The next day it started fine. The temp gauges were in range no problem there so i am stumped. I do have an SCT tuner and it did not show any trouble codes.
Thomaspowerstroke is offline
post #2 of 7 Old 07-17-2013, 02:55 PM
hey thomas, i have the same problem, and i done alot of research trying to find the problem. and i THINK the problem we both have is that the oil rails is losing oil pressure when oil is warm, IN ORDER FOR THE POWER STROKE TO START IT MUST have 500 PSI OR more on the high pressure oil system. if its like my truck she starts fine when cold, runs great when running but when you shut it down and leave it for aprox 10 minutes and try to start the truck it will crank and crank until it kills the batterys and not start because the engine cant build up the pressure when the oil is warm/ thinner and it leats around the seals in the system. i know that the dummy plugs are a common problem, and a svt connection on the High pressure oil pump, its a "SNAP TO CONNECT" fitting that wears out. if u have a scanner or somthin and you get this same problem you can plug in your scan gauge and look at the " injector control pressure" whils cranking. if its less than 500 when she wont start you have a problem in the oil system. I hope this helps. if you find out anything you can send me an email at justincoley200@hotmail.com
justincoley200 is offline
post #3 of 7 Old 07-17-2013, 03:39 PM
Blue Goose's Avatar
what ^^^^^^he said, stc fitting is leaking badly and/or hpop
06 KR 250
Blue Goose is offline
post #4 of 7 Old 07-17-2013, 04:59 PM
does anybody else agree? seems like thats the problem we are having. i just dont have a tool to test the oil pressure. and i dont want to tear into a diesel engine and this not even being the problem.
post #5 of 7 Old 07-17-2013, 06:29 PM
gotta_gofast's Avatar
Quoted: 62 Post(s)
Injection control pressure is a PID so any device that reads PIDs should be able to show you ICP. If you don't have a monitor, it should be as necessary as wearing underwear or pooping in the handicap stall.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #6 of 7 Old 07-18-2013, 02:03 AM
Snake's Avatar
Quoted: 47 Post(s)
Agree that it's a probably a high pressure oil leak. Most people replace the branch tube, STC fitting, and dummy plugs at the same time.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #7 of 7 Old 08-01-2013, 08:58 AM
Best Line...
I have the same problem, has happen to me twice within a couple weeks. While cranking the ICP is around 350-400PSI, right in line with what everyone says.
I'm dreading taking it to the shop to get this fixed.
2005 Crew Cab XLT FX4
MBRP 4" Turbo back cat delete
Edge Insight CTS
SCT X3 w/Looney Tune
mabner is offline
