no power at all - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-15-2013, 04:20 AM Thread Starter
no power at all
04 f250 w/6.0L idles rough and when cold it will barely go, when it warms up really good it does a little better but way below par.it wont rev over 2,000 rpm's,and wont go over 40 mph.oreillys said no codes were on it..i took it to a shop and he gave me 5 codes..p0488,,p1408,,p0263,,p0401,,andp0603.... can someone help? i also found some oil in the coolant bottle...
elhose is offline
post #2 of 5 Old 07-26-2013, 06:58 PM
pull egr valve out of intake see what it looks like most likely stuck and filled with carbon from exhaust.clean it up put it to the closed position reinstall it and leave sensor unplugged and road test.
posreairs2013 is offline
post #3 of 5 Old 07-30-2013, 06:35 PM Thread Starter
i took off the egr valve ,cleaned it and reinstalled it and runs the same, so i bought a new egr valve and still running like crap... frustration has set in, to say the least..
elhose is offline
post #4 of 5 Old 07-30-2013, 06:43 PM
KCCO!!
kells17's Avatar
Oil in coolant? What mods do you have on your truck so we can help you out more. Also, check your oil, is it frothy?
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #5 of 5 Old 07-30-2013, 07:23 PM
does it idle with a misfire or idles normal u cause p0263 is cyl 1 contribution fault.
and the p0488 is egr throttle position control range performance throttle plate accuator sensor. if u take off the 90 degree elbow the drivers side intercooler piping is going to you are going to see something that look just like a throttle plate on a gas car on 6.0 they are used for faster warm up and engine breaking but in normal driving u want that open at all times if accuator sensor went bad it might be half way closed witch will give u a no power issue.
