6.0 Hard start cold 04.5 f-550 - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-10-2013, 03:59 PM Thread Starter
Pistolgrip426's Avatar
Does this sound like classic hpo leak ? Cranks and cranks cold but will only fire with a shot of ether, after running has no problem restarting. Only codes are 2290 and a cam sensor code? But the cam sensor maybe due to excessive cranking?, ficm is 47.5 to 49.5 batt voltages are 13.8 ( both load tested and new) 2290 code been on edge insight for long time before issue started, hpop is approx 3 yrs old, stc fitting new then, dummy plugs both done within last year when injectors replaced. Ipr about 1 yr old same with icp sensor and pigtail. Fresh clean rotella t6 every 5500 miles, all i know that it needs is a new air filter,everything else is fresh.
2004.5 F-550,4x4,6.0,auto,CTS monitored,
Performance Machine egr delete,caterpillar elc,blue spring, CTS Monitor,flat plate agm batteries,K8 code, super tow pkg. (4.88),twin line recovery wrecker.
Pistolgrip426 is offline
post #2 of 2 Old 07-10-2013, 04:04 PM Thread Starter
Just a note, last week had hard time starting, ended up starter guts were failing and drawing massive amps, i swapped out starter sunday no problems at all since, got a cam sensor circuit code a few times, in last few weeks, bought one but never installed it, as codes went away after replacing starter. I still get this cam code when it won't start cold then never comes back once warmed up and working.
