04 6.0 wont crank - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-09-2013, 11:45 AM Thread Starter
04 6.0 wont crank
So, I drove home last night and everything ran just like it always does. Went out to start it this morning and nothin. I turned the key, nothing unusual untill I tried to start. All the fuses are good, the starter relay clicks but the starter does nothing. I jumped the starter and it will turn the motor but still no start! The tuner I have doesnt seem to be picking up when the key is turned. Ignition problem?
I am out of patience and ideas. I need help!
also I had the HPOP replaced 6 weeks ago
Thanks for any help with this,
Chris
04berry350 is offline
post #2 of 5 Old 07-17-2013, 11:12 PM
Pistolgrip426's Avatar
Starter is fried, they go alot w/out warning
2004.5 F-550,4x4,6.0,auto,CTS monitored,
Performance Machine egr delete,caterpillar elc,blue spring, CTS Monitor,flat plate agm batteries,K8 code, super tow pkg. (4.88),twin line recovery wrecker.
Pistolgrip426 is offline
post #3 of 5 Old 10-06-2013, 04:48 PM Thread Starter
well, starter is good, turns out it was the gcm module/fuse panel.
post #4 of 5 Old 11-10-2013, 04:13 AM
Can you elaborate more on the fix please. My 04 is having the same issue. Thanks
05Powerstroker4x4 is offline
post #5 of 5 Old 11-11-2013, 10:56 PM Thread Starter
The whole fuse panel under the dash needed to be replaced. This same problem happened to me again just about a month ago. This time it was the PCM, apparently because the wiring harness shorted it out. Can u hear the fuel pump turn on? Does the water in fuel light come on?
Tags
6.0 , wont crank , wont start
