96 F250 7.3 DI - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-09-2008, 04:19 AM Thread Starter
96 F250 7.3 DI
Started having this problem about a month ago. Truck starts and runs for about several minutes. Shortly after getting up to traffic speed 35 or 40 mph, it stalls for 1 to 3 seconds. Then resumes running. Does that once or twice, and then it's fine. Seems to be worse when running off the front tank. I've changed the fuel filter twice. Didn't help. Ran several tanks of fuel through from different sources thinking contamination. Seems to make little difference. Any ideas? Will check fuel pressure a the filter next. Is the fuel pump suspect? Thanks.
96 F250 4WD 7.3L used mostly as a farm truck
hokie is offline
post #2 of 7 Old 04-09-2008, 05:22 AM
scoobywrx05's Avatar
First off,,,,,Second,, When was the last time you changed the CPS?? If you can check the fuel pressure when the motor is under a load,at WOT it should be in the 40 psi range somewhere and in the 60 psi range when at an idle. I'm thinking its your CPS is whats giving you the trouble though. If you need any more info,let me know,and I'll be happy to help.
scoobywrx05 is offline
post #3 of 7 Old 04-09-2008, 07:24 AM
Shade tree mechanic
95dieselsmoke's Avatar
+1 for the cps, had this happen to me, around 20 bucks to buy, you will find that alot of people on here (including me) keep a spare in the glovebox for a quick roadside fix. they go out randomly without notice. good luck, keep us updated
MATT
Now featuring a 6.4 fat bottum 6 speed
95 f250--238k and counting
RDS stage I's-TW live tuned-Dana 60 swap-9" lift/40x13.5x20 ProComps-ZF5 swap/short throw/South Bend CON OFE-Iron Bull front-AFE CAI-SD innercooler-Fab Tech traction bars-MBRP DP/6" black miters-Autometer boost/pyro
"If you dont have ambition and big dreams, you end up working hard for someone who does"
95dieselsmoke is offline
post #4 of 7 Old 04-09-2008, 07:33 AM
Send a message via Skype™ to demodeke18c
+2 had the same symptoms on my 95. quick easy cheap fix. good luck
95 4x2 CC LWB SW
BANKS PWRPACK
BABY SWAMP INJ
140V IDM
ATS FLYWHEEL
SOUTH BEND CON FE
AFE PRO GUARD
demodeke18c is offline
post #5 of 7 Old 04-09-2008, 07:36 AM
What u talkin bout willis
REDPOWERSMOKER's Avatar
Send a message via AIM to REDPOWERSMOKER Send a message via Yahoo to REDPOWERSMOKER
WELCOME TO THE ORG
2005 F-250
Tuned by Innovative
Deleted by Performance Machine
Coolant filter (Orderd) by Performance Machine
REDPOWERSMOKER is offline
post #6 of 7 Old 04-09-2008, 09:22 AM Thread Starter
Thanks
Thanks for the help. I'll give it a shot and let you know. Great truck otherwise. Had it about 8 years. Only other issue was the o-ring in the hpop. I also appreciate the welcome.
hokie is offline
post #7 of 7 Old 04-20-2008, 05:25 AM
RowdyOutfitters's Avatar
Do try the Cam Sensor, but I noticed you said it seems to be worse on the Front Tank. You may have some trash in there that is restricting the fuel flow or it may be sucking air on that tank. You can get some clear hose and run about a foot or two under the hood where the fuel line goes to the filter and watch it to see if you are sucking air. My cam sensor has gone out twice, first time the engine would shut off and come right back on under a load. The second time it went out it started misfiring and blowing out grey smoke if you got in the pedal. Good luck.. Also, Welcome to the Org..
1995 F-250 Supercab PSD 60hp Edge Evolution, BullyDog Down Pipe with no restrictions. 220K and climbing. LuK SMFW Clutch Replacement. Diamond B Grill Guard/Bumber Replacement. Train Horn by Trainhorn.org. RDS Stage 1 Injectors
Proud Navy Vet and Proud Supporter of our Troops fighting to promote and defend Freedom around the World.
RowdyOutfitters is offline
