Heavy White smoke until warm then no smoke. HELP. - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-04-2013, 02:35 PM Thread Starter
gavol64's Avatar
smoke until warm then no smoke. It's heaviest at idle and when you accelerate. It also jumps around sometimes at idle. Has all new injectors, high pressure oil pump, egr delete done and no programmer. It does use oil and has 199,000 miles. It doesn't use any coolant. I just pulled a large boat back from miami and nothing changed under stress. I'm so confused. No codes. Please help!!!
2003 F250 superduty Crew Cab 4x4 - 4" Rancho lift, Rancho 9 way adjustable shocks, CAT Delete, Royal Purple Synthetic Oil, Royal Purple Transmission and Differintial Fluid, Hypertech Transmission Pan and Differintial Cover, Edge CS Guages, EGT Probe, Dick Cepek 315x75x16, EGR Delete, Roll n Lock Bed Cover, MBRP 4" Turbo Back Exaust, Rev-X, 2005 Grill, Line X Bedliner.
gavol64 is offline
post #2 of 2 Old 07-04-2013, 02:36 PM Thread Starter
gavol64's Avatar
It's a 2006 6.0L .
gavol64 is offline
