97 F250 No Go. CPS? maybe IPS? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-03-2013, 10:15 PM Thread Starter
Irishcream's Avatar
1997 F250 HD 4X4 5 Speed
Electric Fuel, Tony Wildman 6 pos chip
On the way home from work today which is a 20 min highway drive t\he truck started to sputter and cough with a loss of power. I was intending on filling up because I was low on fuel and luckily there was a filling station nearby so I pulled into the station but rolled up to the wrong pump. The truck shut down totally before coming to a stop. I tried to start it again to move over to the diesel pumps but it simply cranked and cranked. I got some help from the gas station attendant and a cook to push my truck to the diesel pumps, put 50 in the front and 30 in the rear tank, filled both fuel filters on the frame rail but it still only cranked. I cracked the fuel lines to the heads with the fuel pump running and fuel came out. The fuel pressure regulator read 60 PSI.
I had previously had and issue with the fuel heater shorting out when I used to have a fuel bowl that popped the fuse for the Injector Control Module but when that happens the wait to start light normally doesn't come on and the fuse number 8 or 22 is toast. I checked every fuse about 5 times, checked and swapped the relays and the wait to start light still comes on. I tried to pull start it as well as jump/boost starting and it only cranks. I cranked it until I killed the batteries and finally gave in a called a tow truck to take it back to my shop. I tried every setting on the TW chip just in case it was a programming issue with not success. I am convinced it is an electrical issue but am hoping it is not a CPU or injector controller because it may be tougher to diagnose. I am going to throw the Snap-on Solus scanner on it tomorrow morning but am hoping someone has had this issue previously and can point me in the right direction.
Facebook Jamie Murphy
1997 Ford F250 HD Powerstroke 7.3L
5 Speed with SouthBend Clutch
Air Ride 3000lb bags with onboard compressor and controls inside cab.
35X12.50X17 BFG M/T
AirMax Spiral Flow System
Napa Air Filter
MBRP 3" Downpipe
Electric Fuel
5" Mitre Cut stacks
TonyWildman 6 pos
Irishcream is offline
post #2 of 4 Old 09-17-2013, 06:05 PM
Did you ever get the pickup running again? my 95 did the same thing, new ICP, CPS, Filters, used two diff. IDM's, fresh fuel, Cleaned IPR and did full field test and it works, new UVCH's and Gaskets really lost with it. The pickup had a superchips programmer on it, so maybe fried the PCM? Im sorry to ramble on ya but figured 2 months and no one has updated this thread so im just guessing(praying) you found the problem!
DI3S3L86 is offline
post #3 of 4 Old 09-17-2013, 06:19 PM Thread Starter
Irishcream's Avatar
It turned out to be the IDM. I even had to get a second IDM because the first one was faulty. Put the second one in and it fired right up. I ended up changing the CPS and it got rid of my high RPM stumble. Cleaned out the exhaust back pressure sensor and tube which was no fun at all.
35X12.50X17 BFG M/T
Napa Air Filter
MBRP 3" Downpipe
Electric Fuel
5" Mitre Cut stacks
TonyWildman 6 pos
post #4 of 4 Old 09-17-2013, 06:28 PM
well maybe I need a third one who knows ill give it a try. Sometimes I just want to throw a match on the thing but life has a funny way of doing things! Thanks for the quick reply
DI3S3L86 is offline
