04 F250 6.0L About to tow from the local Ford Service center - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-01-2013, 07:46 AM Thread Starter
I'm not a motor head by any means, but I love my truck. I'm looking for straight answers that I don't feel I'm getting from the service center.
EGR delete performed before I took ownership. Truck was running a little rough, and not much power right at start up. Died on me a week ago, took it to dealership service center (no warranty) and codes showed 1&5 injectors needed replaced. They replaced and test drove, truck died, hydro locked and codes showed #7 went out. When I asked service manager if he recommended replacing all in that bank prior to the replacement he said, no, but he'd seen some go out shortly after in other cases. I know NOW that I should have replaced all, but I fear that I may be looking at a bent rod and/or cylinder damage. Can anyone tell me what I may actually be looking at to get Hoss running again?
Jessica is offline
post #2 of 6 Old 07-01-2013, 08:01 AM
JUGGS's Avatar
bump the top...
2005 F250 Lariat CCSB/170k mi./6sp Handshaker
Don't Worry
Dieselsite coolant filter, CAT ELC, Bulletproofed and monitored by BPD
Be Happy
SCT SF3, 4" Flo Pro, 2.5" Readylift SST, 35" GoodYear Fierce Attitude M/T's
JUGGS is offline
post #3 of 6 Old 07-01-2013, 08:17 AM Thread Starter
bump the top?
Jessica is offline
post #4 of 6 Old 07-01-2013, 08:24 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Bump this again tonite when all the guys are home from work and I bet you will have better luck.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 6 Old 07-01-2013, 08:28 AM
JUGGS's Avatar
A "bump" is just posting something in someone's thread so that it goes back up the top of the "new posts" page. It's more likely to be seen at the top, or at least on the first page of posts. It's sort of a random act of kindness.
** edit, I just read my post and it should have been "bump TO the top". **
Don't Worry
Be Happy
JUGGS is offline
post #6 of 6 Old 07-01-2013, 08:49 AM Thread Starter
ok, thank you. Was going to start banging on the top of the engine...
Jessica is offline
