'95 f250 powerstroke big acceleration problem - Ford Powerstroke Diesel Forum
Old 04-04-2008, 05:45 AM
Major issue with '95 F250 250,000 miles. runs great under 40 mph. no smoke ever. Once I accelerate to 50 mph, such as when getting on the interstate, engine vibrates to the point of almost hoping out of truck and loses all power. I had to stop on the side of the road controlling idle for it not to stall. After about 3 minutes can continue on but if I reach 50 mph same thing happens. Barely made to a shop's parking lot last night and waiting for them to open this morning. Any ideas what this might be. I need the truck Monday morning.
Thanks
Old 04-04-2008, 07:05 AM
Fuel flow problem. Restriction in filter or pressure regulator, fuel pickup in tank, weak fuel pump etc.
Old 04-04-2008, 07:20 AM
Fuel restriction problem
Old 04-05-2008, 07:22 PM
Thanks for the Help
Update:
I changed air filter, fuel filter, cam position sensor, neutral safety switch and same symptoms. I discovered that I have no problem at all if I use the rear tank and not the front one. Therefore my problem occurs only when using the front tank on a dual tank system.
