6.0 fuel issues ? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-30-2013, 08:04 PM Thread Starter
6.0 fuel issues ?
Just finished changing oil cooler and egr cooler on my 06 f250 tried firing it up and tries to start but no go tried purging air from the fuel lines that feed injecters was some air at first checked ficm 48.7 key on 42 cranking any suggestions
joshclemens is offline
post #2 of 6 Old 06-30-2013, 08:48 PM
hdodt's Avatar
Did you fill the oil reservoir up in the valley? If not that's your problem. Dump a couple quarts down the oil filter canister and crank... check all connections (especially the ficm) to make sure they are right.
2006 F350 Lariat
EL CAT1 coolant and coolant filter.
95k miles. Oil cooler changed at 93k.
Oversized turbo oil drain tube.
hdodt is offline
post #3 of 6 Old 07-01-2013, 04:21 AM Thread Starter
I did fill up the sump then checked oil level after cracking for a while took a whole gallon between the two
post #4 of 6 Old 07-01-2013, 04:40 AM
Unapologetically American
2006PSDSD's Avatar
Quoted: 24 Post(s)
Feedback Score: 4 reviews
Be sure that all connectors are securely attached to the FICM, and that none of the pins are bent over. You can pull the secondary fuel filter top and be sure there is fuel in there. How long have you cranked it over? Mine didn't take long at all; less than ten seconds cranking . Something wasn't put together right
2006 F350 SOLD
* KMC XD Monsters wrapped in Hankook ATM's
* 08 style mirrors
* 4" TB exhaust
* SCT X2 with Gearhead, PHP and ID tunes
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Dfuser coolant filter
* Stage1 MTW turbo
New truck has a Cummins and a handshaker
2006PSDSD is offline
post #5 of 6 Old 07-01-2013, 06:56 PM Thread Starter
Rely appreciate the advice I was so sure the connections on ficm were good one was loses I don't know how but it was it fired right up thanks again
post #6 of 6 Old 07-11-2013, 04:53 PM
Pistolgrip426's Avatar
Ya dang ficm wiring, had one doin same thing just changed out harness and no more issues
2004.5 F-550,4x4,6.0,auto,CTS monitored,
Performance Machine egr delete,caterpillar elc,blue spring, CTS Monitor,flat plate agm batteries,K8 code, super tow pkg. (4.88),twin line recovery wrecker.
Pistolgrip426 is offline
