Driving and all of a sudden no power then it shut off. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-24-2013, 10:39 PM Thread Starter
doing maybe 55-60 i notice no power then it just dropped to 0 rpms.
when cranking the ICP is no higher than 390. that mean its a HPOP? usually when idling its anywhere from 550-900.
Dip stick wasn't showing much oil in it so i threw 10qts into it and it still wasn't hardly showing so it may just leaked everything out even tho i could not see any oil spots, was at night tho as well.
anything else i can check, truck will not even try to start.
dominic600 is offline
post #2 of 4 Old 06-25-2013, 05:08 AM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
Without oil pressure your HPOP won't work. It's hard to believe that you put 10 quarts of oil in it and it disappeared. Now that it's daylight you might want to take another look.
AshevilleEngine.com is offline
post #3 of 4 Old 06-25-2013, 06:56 AM Thread Starter
yeah I'm about to go head over to where it is. I had the ICP sensor o ring break on me and it leaked more than 5qts just idling for like 2 mins. It looks wet again so i may have been that but the bottom of the motor didn't look real oily.
post #4 of 4 Old 06-25-2013, 09:44 AM Thread Starter
well truck started, i added oil now its way over the max line so i have to drain some..
when i hit the throttle the rpms actually drop or don't move at all and it'll puff out blue smoke?
is this because to much oil, not throwing any codes other than for the egr delete
