Bad fuel or injectors?? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-24-2013, 07:00 PM Thread Starter
Turbo_Fontenot's Avatar
My truck idles and cranks up fine but when I'm driving it shudders and puffs out black smoke. If I put it in park and hold down the pedal it will shudder and puff black white or blue. It will do this at random RPMs like 1800 or 2100 but max out at round 3000 feeling like power is barely there. I changed my fuel filters twice within 5k miles both being bad. Could this be bad fuel? Or injectors. All started after I filled up the tank the night before.
05 6.0 f250
2005 F250 6.0L King Ranch
Turbo_Fontenot is offline
post #2 of 6 Old 06-25-2013, 05:12 AM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
You say it all started after refueling. I would have to assume that you've had some problem that has been going on for a while if you changed your fuel filters twice in the past 5,000 miles. What else has been wrong? If there's water in your fuel your light will come on telling you to drain the filter. Did you use genuine Ford filters or aftermarket?
AshevilleEngine.com is offline
post #3 of 6 Old 06-25-2013, 05:13 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
hows the FICM?
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #4 of 6 Old 06-25-2013, 06:49 AM Thread Starter
First fuel filter I used was motor craft. Now I have a fuel filter that's purepro. I fill up today with power service clear diesel and injector cleaner and imedently the truck had no spudder or hasition. I haven't had the WFL on but when I did the filter change last I got a cup of the diesel that came out and it was apple juice in color
post #5 of 6 Old 06-25-2013, 06:50 AM Thread Starter
I haven't tested the FICM yet.
post #6 of 6 Old 06-26-2013, 06:11 AM
Quoted: 7 Post(s)
ditch that filter its gonna kill your truck. back to motor craft asap.
