6.0 Ran low on fuel Now won't start - Ford Powerstroke Diesel Forum
post #1 of 21 Old 06-24-2013, 04:01 PM Thread Starter
04WHTCREW's Avatar
Send a message via AIM to 04WHTCREW
Hey Guys,
I have an 06 6.0 and the other day I was hauling horses and was in a area that had no fuel so I end up at 3 mile to empty when I finally got to a station. It was starting to sputter a little. I filled up and it started right up and ran great for 25 miles. It acted like it lost power for a second and then straighten up. Then about a mile later it was like you turned the key off. And will not start back up. Going to start with fuel filters but does anyone else have any input. Thanks in advance
04WHTCREW is offline
post #2 of 21 Old 06-24-2013, 04:05 PM
novemberdelta's Avatar
Quoted: 3 Post(s)
Any codes? Ive seen people run out of fuel and ruin injectors on these. Did you cycle the key a few times to get any air out?
2015 F-250 XLT
Fisher 8.5' Extreme V Snow Plow
novemberdelta is offline
post #3 of 21 Old 06-24-2013, 04:29 PM Thread Starter
04WHTCREW's Avatar
Yes cycled the key several times.
post #4 of 21 Old 06-24-2013, 04:34 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Damn, I had my needle burried on my 6.0 and was at 0 miles to empty and it still ran fine, Granted i didnt drive miles like that the fuel station was right up the road.... But i hope you figure out whats wrong!!!
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #5 of 21 Old 06-25-2013, 05:14 AM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
Check your fuel filter for crud. Running that low you may have sucked some crap out of the bottom of the tank.
AshevilleEngine.com is offline
post #6 of 21 Old 06-25-2013, 05:23 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
after filter change cycle the key a few times with the top filter loose to get the air out of the lines.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #7 of 21 Old 06-25-2013, 05:31 AM
ZMANN's Avatar
Quoted: 1596 Post(s)
there is a pretty fine screen in the bottom of the tank to keep that from happening and the pick up foot is supposed to be on the bottom of the tank
and those little ridges you see help as a pre filter for the screen
so if anything gets by it will be fine sediment or water
so agreed start with draining the water separator and doing filters
if no go test the fuel psi at the test port on the regulator
you sure you got diesel fuel ?? and I hope it's not injector damage as they depend on fuel being present to cushion the injection cycle
We Miss you Ronnie
ZMANN is offline
post #8 of 21 Old 06-25-2013, 05:40 AM
Hopefully this clears up with the filters being changed out. Not sure where you got your fuel from but it you got it from a rink a dink gas station way out in the boonies you may have got some bad fuel.
99.5 F250 7.3 (Sold)
2006 F350 6.0 CC LB SRW FX4
Pro Comp 2.5 Leveling Kit
New Premium FICM from Ed
IPR GEN 2 EGR Delete w/ Up Pipe
Flo Pro 4" Turbo Back w/muffler
Blue Spring Mod
SCT Livewire ts
Ag Street Tune by Eric
NCDeerHunter is offline
post #9 of 21 Old 06-28-2013, 05:08 PM Thread Starter
04WHTCREW's Avatar
Ok started to change filters and started with the top one. Fuel bowl was full when I took the cap off. pulled the filter out and cycled the key to see if I was getting fuel. I have lots of fuel. It over flowed the bowl. Put the new filter in and decided to try it again. Cycled it a couple time still no start
post #10 of 21 Old 06-28-2013, 05:14 PM
ZMANN's Avatar
is that fuel at 60 psi ?
it's better to just test at the test port
We Miss you Ronnie
ZMANN is offline
