charging problems - Ford Powerstroke Diesel Forum
post #1 of 16 Old 03-29-2008, 10:50 AM Thread Starter
dgw65's Avatar
charging problems
I'm getting ready to pull my hair out. Batteries went south last fall. I didn't have time to replace them so it sat for the winter. 3 weeks ago I put brand new yellow top optimas in it. Had a hard time starting it, i guess my block heater or cable is bad too. After trying about 10 times, letting the starter cool inbetween tries, it finally started. After a few minutes of running the alternator pegged 18. I don't know how long it was there but no more than 2 or 3 minutes. Then it wasn't charging at all. I took the alternator off last week and took it to a rebuild shop and it tested fine on the bench so the guy tells me there was a lot of problems with the stator shorting out intermittently so I had him go through it. Picked it up yesterday and put it on. It still isn't charging. New batteries, should be good alternator, all connections are clean and I checked voltage at field wires 12v on 1 1.5 on the other. Anybody got any ideas.
Thanks
dgw65 is offline
post #2 of 16 Old 03-29-2008, 11:22 AM
eschaner's Avatar
What do you have at the batteries when it's running? If you have 12 V when it's running it's not charging. Should be around 13-14v. Is the ground cable tight? and connected. Possible broken wire. Electrical problems sucks period.
Eric
2002 F-250 SD 4x4:burnout
afe stage 2 air intake
4" dual exhaust w/ delete Y pipe
2" leveling kit
ats turbo housing w/ x-wheel
Tony Wildman chip
Firestone destination m/t's
Ultra 175 Rogue wheels
tri-pod w/fuel pres, ex.temp, boost
Zoodad mod.
Foil delete
Rhino lining
eschaner is offline
post #3 of 16 Old 03-30-2008, 02:17 AM Thread Starter
dgw65's Avatar
yeah, only 12.15v at batteries. grounds are cleaned already top and bottom.
dgw65 is offline
post #4 of 16 Old 04-03-2008, 12:05 AM Thread Starter
dgw65's Avatar
Only get to be home 1 day this week. Am I missing something easy
dgw65 is offline
post #5 of 16 Old 04-03-2008, 07:09 AM
rdc
Grumpy Non-Socialist
rdc's Avatar
If battery cables are good, and lead from alternator is good, then the
problem is still in the alternator.
Russ Cook
2008 F250 FX4 SC LB 4wd
visit
FabFours bumper/brushguard
Cook's Calibers, LLC
Warn winch
Freedom isn't free, but we make it cheaper!
My other diesel is an Olds
rdc is offline
post #6 of 16 Old 04-03-2008, 07:21 AM
Conservative and Proud
Banshee34's Avatar
Quoted: 9 Post(s)
Just checking, but I have two alternators.... is this a possibility on your truck?
2001 F350, Lariat SC LB 4X4 PSD
Quadzilla Commander
Zoodad with Stealth Screen
The Org. Staff reserves the right to move, modify, delete or merge posts at our discretion and without explanation.
Banshee34 is offline
post #7 of 16 Old 04-07-2008, 02:45 AM Thread Starter
dgw65's Avatar
Only 1 alternator. All fuses are good. I am going to pull it off and take it back for a bench test.
dgw65 is offline
post #8 of 16 Old 04-13-2008, 03:50 AM
MahdeyS's Avatar
any updates on this?
MahdeyS is offline
post #9 of 16 Old 04-13-2008, 04:11 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
You have two alt's Tiff, was yours set up for an ambulance prep or something
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #10 of 16 Old 04-13-2008, 04:50 AM
Desert Shield/Storm Vet
vitalidle's Avatar
Also check your wiring if the alt checks good on the bench again. I believe you have the batt wire and then an ignition wire also that needs to provide voltage when you cycle the key for the alternator to excite the field so it will work.
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
