04 6.0 white smoke!!! - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-21-2013, 07:20 PM Thread Starter
okay now i know you've all heard this one allot im just trying to pin point the problem for sure before i start the tare down. its a 04 f250 6.0 powerstroke with 59xxx on it. put a edge juice with attitude and ran it on 2 was fine for a while well tonight was the night i figured why not so bumped it up to 3 no problems lil more smoke went to 4 lil more black smoke went to 5 lil more did this for maybe 10 mins then one last romp before i turn it down and go home. and i hear a noise kind of like a bump i thought the edge was maybe defueling no big deal till the white smoke came. rushed it home smelt the exhaust smelt of diesel, check the coolant was full at the max so i figured im good checked the oil and none on the stick. any and all help would be great guys and sorry for righting so much...
jordanl is online now
post #2 of 2 Old 06-22-2013, 01:50 PM
Does it have an egr delete? Cooler may be going bad, and the bump sound might have been a coincidence. Also look in your turbo for black residue, you can have a seal going bad in the turbo, and the chip would explain that. Although a chip wouldn't normally harm that unless the turbo seal was already going bad. Let me know what you find!
ColtonH00 is offline
