Help! 6.4 egr delete problem! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-21-2013, 12:51 AM Thread Starter
So today I installed my egr delete on my 6.4, everything went good, everything came out well, I put the plates on then I tried to put in the coolant bloCk off plates. Neither of them went in all the way, so I tried tightening the bolts that hold them in, and it made one side go in but the other side would stick out. Anybody else experience this? I managed to tighten one where it wouldn't poor coolant but the other one leaks. Whoever has done an egr delete themselves, did yours pop right in? Or was it a ***** to get them in? Am I missing something??
ColtonH00 is offline
post #2 of 3 Old 06-22-2013, 01:45 PM Thread Starter
For anybody looking at this, I figured out what happened. So I pull out the plug, and checked the o-ring, and it was fine. But it was really dirty, had dirt all over the o-ring. So I cleaned it off, wiped some oil around the ring, and I put back in the engine. When I tightened it I didn't over tighten it so it was even all the way around, and not one side popping out and one in due to a single bolt. Now it works fine, doesn't drip at all.
post #3 of 3 Old 06-22-2013, 02:23 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
Should go all the way in. Be sure to not tilt it to push it in. Keep it flush and lube is your friend
Big_Smokey is offline
