I am wondering if anyone knows if the change in the diesel type (LSD to ULSD) would cause damage or premature failure to the injector orings and seals? Would the ULSD dry the o-rings out and cause leaks?
My 95 PSD is running horribly bad. I was getting about 23MPG and then one day it started to have a miss and my fuel mileage went down to about 12MPG and I don't have any power, especially if under load 5K plus. I have had it tested a couple times, no codes and good contribution tests. I really think I have a injector problem but unfortunately no mechanic can tell me if that is the case. FRUSTRATING.... |
Are you using any oil? Check your fuel filter for oil and see if you are low on oil. I had bad injector o-rings after the ULSD fuel change and started to burn oil. The dealer has an injector kill box that could also check for dead cylinders. If all injectors are not contributing equally it will pass the cylinder contribution test. Cylinder contribution looks primarily at large differences of cylinders relative to others. Hope this helps
good luck with it.
there was another thread I was reading about Sea Foam. sounds like something to consider maybe....
Sea Foam |
My '95 was leaking fuel to the point where fuel was on the ground. I changed the fuel filter/water separator and it quit leaking as bad. The leak was due to the o-ring shrinking due to the fuel change. Also, check your supply pump in the engine valley. (It's underneath the black cover on top of the engine) There is a weep hole on the bottom of the pump that leaks if the seals go. (Mine does this also, due to the fuel change) If you have fuel in the valley, more than likely that's your problem. The pump is about $150 from the dealer, but the turbo pedestal has to be removed to replace it. As for mine, the leak is annoying, but the truck runs fine and the pump isn't going to fail (just leak). Also, the seven hour labor charge is somewhat painful. Hope this helps.
my buddy just changed the injector o-rings and that fixed his problem. the o-ring kits arnt expensive and make a big difference. good luck
hey i have been getting bad mpg and about every 3000 miles i used a qt of oil do you think my o-rings are bad its a 02 7.3
