EGT probe? help bfr tonight - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-10-2013, 02:05 PM Thread Starter
I have an 06 6.0L F350 CC SB ZF6 FX4 finishing up a whole lot of work on it. Head studs, regulated return fuel, updated stc, updated standpipes/dumby plugs, updated CACtube, CCV relocate, MAD MOD Ypipe, BPD oil cooler system, 5in turbo back straight pipe, short shift kit, and just ordered the Gryphon FICM tuner (Edge Evo) with egt probe from power hungry performance.
Now if someone could tell me what size to drill and tap my exhaust manifold for the pyrometer before I put it back on that would be great!
Need the truck tmro night fingers crossed. want to drill and tap manifold and just plug it off until my gryphon gets in. that way i wont have to worrie about drilling on the truck or pulling it again.
Nightwolf881030 is offline
post #2 of 4 Old 06-10-2013, 02:14 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Right where the drivers side manifold starts curving and heading up to the turbo. Theres plenty of room to get a drill up there
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 4 Old 06-10-2013, 02:26 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
All sorts of video's on youtube as well. Thats were I got my nerve up to poke holes in a perfectly good not leaking exhaust system.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 4 Old 06-10-2013, 06:28 PM Thread Starter
(2003ford) over at psn hooked me up its 1/8"-27npt 5/16 drill bit. also found vids on tube thanks.
