fuel tank help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-08-2013, 09:10 AM Thread Starter
fuel tank help
I have 95 ford 7.3 diesel powerstroke. 260k miles. my problems started when I had back fuel tank swapped out because it was rusted out. now truck runs fine on front tank but when you switch it to back tank it will run a few miles then starts missing and will stall and not restart until switched back to front tank, after a few cranks she will start on front tank again run fine again until switched to back tank. We replaced fuel filter, and fuel tank switch regulator. Still wont run on back tank. Any suggestions quick would be greatly appreciated.
bshouse is offline
post #2 of 2 Old 06-08-2013, 09:56 AM
jesilvas's Avatar
Quoted: 3 Post(s)
I'd suspect something in the rear tank not hooked up, and you're sucking air. Or the back tank is empty.
4R100, 2wd
330,000 + miles
jesilvas is offline
