wrong diesel used low sulfur in the 08 - Ford Powerstroke Diesel Forum
Old 03-15-2008, 03:32 PM
I just put in 19 galons of low instead of ultra low in my 08, the sales rep at ford said to just keep toping off the tank until i burn out the low sulfur. Has anyone had this issue and is there another fix besides draining the tank? additives?
Old 03-15-2008, 03:42 PM
ADMIN AND TECH
just keep adding some ultra low as you drive it , and it should be fine
Old 03-15-2008, 03:46 PM
thanks i started to panic! is there an additive that i can put in it to help it along the way?
Old 03-15-2008, 03:47 PM
ADMIN AND TECH
it will be fine
Old 03-15-2008, 03:57 PM
I actually got into a spot a couple times with the low sulfur (500 ppm). I believe the book says damage to the DPF will ocurr if using any fuel higher than 500 ppm. I haven't had any emisson related problems. It does make for a better smoke screen during the regen.
