7.3L Coolant Leak - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-03-2013, 07:51 PM Thread Starter
7.3L Coolant Leak
bought the truck with 140,000 miles on it, its a 1999 7.3 manual, at first there was a small coolant leak in the therm housing and the weep valve was leaking coolant in the water pump, so then I had the pump replaced by a shop for about 550, now fast forward about a month. after frinally getting a day off I whip out to 7-11 and come back and realize that I just drove into a big puddle of my own coolant no previous signs of leaking, no small puddle, as in it must have happened overnight, so as a new poster with a old problem I come to you guys with questions, what the hell could be going on with my truck? and If I have to drive my truck tomorrow is there anyway I could do it ? is there anyway the truck could take running on distilled water so I can just get the the shop without a tow? Thank you so much for your help, I am beyond frustrated at this point
Creamypies is offline
post #2 of 8 Old 06-04-2013, 12:53 AM Thread Starter
bump, anyone ?
post #3 of 8 Old 06-04-2013, 01:53 AM
belz's Avatar
Quoted: 70 Post(s)
Have you looked to see where it is coming from? Did you replace all the hoses and get a new thermostat housing?
Belz
CPA Director
belz is offline
post #4 of 8 Old 06-04-2013, 09:58 AM Thread Starter
Yes, cant find the exact point, replaced the thermostat, dont know if all hoses were replaced because I didnt do the work
post #5 of 8 Old 06-04-2013, 10:54 AM Thread Starter
was able to find that it was coming out of the bolt that was screwed in behind the elbow piece that connects to the lower hose coming out of the water pump, took some pictures since that probably wasnt the best description
the new water pump is on the bottom right, leak in the middle coming from that screw, is it a crummy gasket ?
more pictures
to the left that is the lower radiator hose
and one last from the top
post #6 of 8 Old 06-04-2013, 10:55 AM Thread Starter
for some reason that didnt work imgur: the simple image sharer
post #7 of 8 Old 06-04-2013, 10:55 AM Thread Starter
and the second link did, thank you guys for your help
post #8 of 8 Old 06-13-2013, 02:39 PM
belz's Avatar
Quoted: 70 Post(s)
I don't have that big elbow just a little adapter but I think mine is leaking from there also after I did the new pump.
Belz
CPA Director
belz is offline
