95 - 7.3 Will not start
I have a 95 F350 7.3 dually with only 75k on it, that has been sitting down at my local ford dealership for going on two weeks now, and I do not think the mechanic has a clue about what is wrong with it.
First it had been getting hard to start in cool weather, then it burped and shut down in a parking lot the other day. After a few minutes it fired up and ran on home. Then would not start the next morning. Late that evening I tried to start it and it did not. Then twenty minutes later it fired up and ran, took it for a little drive and all was good. Back home and killed it and then checked to see if it would restart and no, that was the last time it started. It was getting fuel to the fuel filter, so I replace that and replaced the cam sensor. Still not start, checked all fluids ok, checked the #22 fuse ok. Check oil level in the high pressure resv. So it was towed in.
First they said I had a problem with my fuel tank relay to the aux tank (remember it was getting fuel at the house), and rewired that, and then found it was the high pressure pump (and or sensor) on the injectors, they replaced that and said, that there were two fuses blown, (#8 and #12, I think). Well then it was the PCM module sending bad codes, so now they have ordered it and maybe it will work.
The truck has been sitting on the work lift in the shop for a week and two days (it was pulled in a week ago Wednesday). They finaly said the PCM has been shipped and should be in Monday, so I might get lucky and have it out Tueday or Wed, only two weeks.
When I went in to check on it and find out what fuses were blown I found the mechanic had the owners manual for the 7.3 motor out of the glove compartment doing the trouble shooting on the fuse box.
Does the dealership have a check list that they are to use to check a hard to start vehicle? and what would suggest I do at this point.
Sorry to be so long, and thanks for any help if you can.
