I have a 03 F-350 6.0 152 000 miles. It was blowing huge clouds of black and white smoke continuously before I shut it off 15 minutes ago. Now it will not start. Oil is coated everywhere, on the back of the truck, on the trailer and the oil level is below minimum which was full an hour and a half ago. Now just dripping the small remains onto our driveway. Lots of steaming from the engine too. Please help me. My business depends on this truck.
The 03's were know to have a problem with the ICP sensors. Oil leaks through the sensor and oil soaks the pigtail and leaks down the back of the engine.
What about a leak on the drivers side in behind the tire a few inches? Thats where the leak is. To my understanding the ICP is over towards passenger side? Yes? No?
A lot of guys say they go from the bottom but I remove the degas bottle and FICM and go from the top. It's a pain bit can be done. You can crawl under neath and look up to the ICP and you'll be able to tell if that's the source of your leak.
No problem.:thumb: If it is indeed the ICP, buy the part from Ford and buy one for an 04 or newer truck. Get the pigtail also. It will be a little more expensive, but I've learned my lesson using after market sensors + this one is a PITA and you don't wanna do it twice.
could be your oil pressure sensor to it's right beside the turbo feed line and could also be your turbo drain tube also with bad oil ring.i can have turbo off by the time most people
take the ficm and degas tank off you could say i've done a few.but it's easier for me to take the turbo off.
we need to see if you are building any oil pressure
So I made the story seem like it was me driving. It was actually my dad. He said he heard a bang and then it smoked like hell that last 1.5 miles until it reached my home. My dad thinks he threw a rod. What are possible scenarios with that statement added in?
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
