Leak between oil pan and transmission pan - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-30-2013, 01:38 PM Thread Starter
While changing my oil this afternoon I noticed a tiny holy in the pan directly between my oil pan and transmission pan. It looks like watery oil is coming out anyone A know what this pan is? B Know how to fix it? Or should I go to my mechanic? I searched and couldn't find anything online on this topic.
nmj1199 is offline
post #2 of 10 Old 05-30-2013, 03:16 PM Thread Starter
Ooops its a 2002 7.3
nmj1199 is offline
post #3 of 10 Old 05-30-2013, 03:55 PM
t-ray-4ray's Avatar
Quoted: 89 Post(s)
Search for a fuel leak in the valley of the motor it's coming from the top probly fuel bowl leak mixing with dirt and oil
Sent from AutoGuide.com App
2000 f-350 4x4 extended cab, went from a flatbed work truck to what you see now, all done by me. Early 99 engine, billet low stall converter, rebuilt trans, all new uvch, new belt tensioners and idler pulley, rebuilt injectors, all new icp, idm, cps, hutch mod, k&n intake, white valve covers, wicked wheel, 5 inch exhaust, php hydra chip 15pos, 8" superlift, 20 inch black and machined rims, 2" billet spacers, 37/13.50r20 toyo open country tires, rough country dual stabilizer, 05 front end with 10k hid lights, amber led cab lights, 09 ford van bucket seats, 2010 f150 center console, b&m ratchet shifter, aero force scan gauge, b&m trans cooler used as a fuel cooler,
t-ray-4ray is offline
post #4 of 10 Old 05-30-2013, 04:28 PM Thread Starter
No I can see the hole its in the small pan inbetween the oil pan and the trannny pan it looks like something kicked up and put a hole in the bottom. There are four small bolts holding the pan up I need to know what it is so I can replace it.
nmj1199 is offline
post #5 of 10 Old 05-30-2013, 04:48 PM
Sounds like your talking about the torque converter cover. Only oil or tranny fluid could come out of there, and that's unlikely as it would be your rear main seal, or front tranny seal. There's a 99% chance that you have a leak on top of your motor that is running out of the drain hole at the back of the valley, and down the back of your motor between the oil pan and tranny pan. This is extremely common in these trucks. Look on top of the motor, under the fuel bowl and turbo to see if its wet up there.
1996 F350 CCLB, 4x4, 4:10, auto, tymar intake, 3" dp, 4" SS exhaust, gutless kitty, gauges, ts 6 pos, ebpv delete, ww2.
Trucknt is offline
post #6 of 10 Old 05-30-2013, 04:51 PM
ZMANN's Avatar
Quoted: 1661 Post(s)
the e40d torque converter cover pan ? if so it isn't meant to hol anything in liquid wise just to keep fingers out basically
We Miss you Ronnie
ZMANN is offline
post #7 of 10 Old 05-30-2013, 04:54 PM
ZMANN's Avatar
dust shield
E4OD Automatic Transmission Inspection Cover - Dust Shield Cover - E40D E4OD on eBay!
We Miss you Ronnie
ZMANN is offline
post #8 of 10 Old 05-30-2013, 05:17 PM Thread Starter
OH thanks for the info it must be oil and building up behind it and leaking out. Thought it might be alot worse.
nmj1199 is offline
post #9 of 10 Old 05-30-2013, 05:21 PM
t-ray-4ray's Avatar
Quoted: 89 Post(s)
That's what I tried to say. Wash out the valley with some degreaser and watch. Go to guzzles web page and read about the fuel bowl rebuild the oring set is cheap and only takes about a hour
post #10 of 10 Old 05-30-2013, 05:21 PM
nohsp4u's Avatar
Mine is doing the same as yours, i have a small leak in the fuel lines a top the engine. Thanks to the brains on this site, i found the source......still waiting for someone to show up and fix it.......waiting... LOL
1997 F-350 XLT Lariat Crewcab long box 4x4. Oxford white with an ugly green. 133xxx miles. Hide away goose neck, banks turbo, exhaust, inner cooler, intake filter and gauges.
nohsp4u is offline
