SMMOOOOOOKINNGG BAD !!!
i put this in the 911 for extra exposure
had this 96 f450 (180k miles on it) for about a year. hardly hardly use it. about 2 months ago, it was about a 40degree morning. started and there was big hissing. since, i have find out that that's ok - helps the engine warm quicker. but major major smoke cloud has happened since. white-grey (noxious - not water) smoke billows out of the exhaust which makes such a cloud that big rigs have to hold back behind me. it does not go away and just smokes and smokes. i opened the hood and there was some smoke coming out of passenger side at turbo. the clamp there was really loose so i tightened it but made no difference. also, masses of smoke from drivers exhaust manifold. had the gasket at the manifold replaced ($300) and the smoke is still there. the mechanic said there was a lot of oil in the turbo but that he thinks it could spin by hand. from my search, i can only guess it could be 1 injector o-rings 2 turbo o-rings/seals 3 turbo is broken and needs to be replaced. the truck starts fine, pulls ok but has a rough idle. |
Bumping this up for ya!
Take off the intake and see how much shaft play is in the compressor wheel.
But i have a feeling it is injector related. |
yeah, like the video, only without the tap and the smoke from mine may be a little bluer but at least as much. the smoking does not go away, even when warmed up and on a warmish day (65degrees)
no real strange noises - it idles a little rough but no taps or bangs. |
At those miles I would think injectors but you already replaced two of them and still get contribution codes for the new ones.
ok blue... I'd say it's an injector issue. Probably O rings.
Blue smoke occurs when oil is entering the combustion chamber and is burning along with the fuel. I don't think it's a turbo issue because I've seen the blow blue smoke when the shaft is broken, but they wouldn't be able to build any boost or power and it was certainly noticeable. |
matt
'At those miles I would think injectors but you already replaced two of them and still get contribution codes for the new ones.' you must be thinking of someone else. i haven't done this. i was 'hoping' it was the o-rings. seems like the most straightforward repair (and cheapest). i got a quote for $160 done. doesn't sound bad but maybe i could get it done myself in a couple hours. |
If you were serious about doing it yourself I can supply you with some links.
However - even though you can find help and instructions here you are ultimately responsible for what you do to your truck. http://www.powerstroke.org/forum/7-3...r-removal.html 1999-2003 Ford 7.3L Powerstroke Injectors Last edited by Marty; 03-11-2008 at 12:52 PM. |
thanks. i would like to take a look at the method - in that way i could make a better judgement as to whether i can do it myself or not. i know that if you have a bad injector, one method for diagnosis is to pull them one-by-one to see which one is causing the smoking. first of all, is there any particular way to do this and secondly, would this help to dignose o-ring problems or is it just prudent to change them all while you're there. anyone else think it's injector related? the mechanico kept pushing a replacement turbo, but i am not sure about that. |
