new pcm wont start on different tuner setting! help! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-28-2013, 08:59 AM Thread Starter
Recently I just installed a new Pcm because my old one was in a "confused" state
So when I start my truck on stock it starts fine, no codes, everything works, except when I give it a lil rpm's it blows a puff of blue smoke...
If I hold it to the rev limiter it goes straight to 3500 with no bouncing like it used to.. and blows white smoke from around 2800 to 3200 then clears up
Now when I go to put a different tune on (using edge evolution 15001) it won't start...I don't hear the fuel pump kick on but every other sound it makes is the normal start up sounds
It will just crank and crank but nothing... on the tuner with the truck off it says I'm at 16 psi boost ...
Now when I run diag on it through the tuner if brings up
P0221 - throttle position switch b circuit range/performance
And sometimes it reads camshaft position sensor circuit malfunction
P0603 - kawpr or something like that I would have to look again (on phone and can't switch)
The pcm I just installed is the exact same as I pulled from my truck... same dpc number and everything... only difference is this pcm was in a roll over..
Now I don't think the roll over part has anything to do with it because it runs fine on stock.
Anyone have any ideas?
( yes I know edge sucks but it was free from a friend so I took it)
Also
magikalshots is offline
post #2 of 6 Old 05-28-2013, 09:13 AM
Term3's Avatar
Ideally the PCM should be "married" to the FICM so it may just be a bit of confusion between the two of them and flash versions.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 6 Old 05-28-2013, 09:15 AM Thread Starter
Ah that makes sense ..
So should I take it to ford and have them reflash it to my trucks VIN and stuff?
post #4 of 6 Old 05-28-2013, 09:26 AM Thread Starter
On stock it runs a code
P0603 - power interruption on (kapwr) circuit
post #5 of 6 Old 05-28-2013, 09:54 AM Thread Starter
When I try to put a tune on it runs these 3 codes
P0340 - CMP circuit fault
P1210 - injector control pressure above expected level
P0221 - throttle position switch B circuit range/performance problem
post #6 of 6 Old 09-27-2013, 12:35 PM
jpalma's Avatar
I am experiencing the same thing with my edge I got cheap. Have you figured out whats going on?
2000 F250 Crew Cab, 366,500miles
,6637,Foil delete, Smoked Cab lights, Bed Liner Rockers, Muff. Delete,08 DIff Cover, 50 Gal Transfer Flow Tank
jpalma is offline
Tags
new pcm , no start
