Please help high pressure pump - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-24-2013, 07:42 PM Thread Starter
Fixed fuel leak in steel line rubbed hole in it from the filter housing . Would not start after put back together oil pressure was only 150 when we scanned it put used pump own started right up ran for about 30 minutes went dead would not start back scanned it same thing 150 oil pressure so we put new pump own cranked up great ran for about a day went dead would not start again so we checked the pressure again it is 150 what is going on cant afford to keep buying new pumps please help in bama
heavy mechanic is offline
post #2 of 4 Old 05-24-2013, 09:09 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
As good as we all are, we really don't know what truck you are talking about.
Some specific info would help
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 4 Old 05-26-2013, 04:38 PM Thread Starter
7.3 problems
Ok it is in a e350 bus but is the same motor as in our f350 super duty oh yea it is a 98
post #4 of 4 Old 05-26-2013, 04:42 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Ok, so a 7.3.
You need to use a mechanical gauge to see what your low pressure oil pressure is and what your high pressure oil pressure is.
I would also suspect an IPR issue as it seems to do it when hot?
4R100, 2wd
330,000 + miles
jesilvas is offline
