fire truck down - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-23-2013, 12:06 AM Thread Starter
fire truck down
My dept has a 2000 or 2001 psd crew cab 4x4 cab and chassis truck out fitted for grash and forest fire, that has been down for over a year. This is a small volenteer dept and has had a bunch if coobber wanna bes" looking at" it.
I havnt had time to mess with it myself ( been to busy working on my cummins). This is ny first week back on dept and chief has ask me to " look into it".
Ok here is what I've been told. Pump in tank has been replaced. Pump on fram below driver has been replaced. When frame pump is hot wired truck will run fine. Simple hot wire straight to battery and truck will run. Or at least idil. No on has m essed with in so long nobody can tell me what Is actually wrong with it. Some one said something about a (wet fuel injection harness plug on back of intake said it was 30 $ part.) I can't find one on rovk auto or Diesel auto power so I'm assuming that's wrong. Does this sound like a common proplem? Any thing in particular to look at when I start trying to diagnos?
What other problem do I need to look for from it sitting?
I'm ok for mechnicaly savy. My cummins is my first deisel and I know these PSD are a differnt ball game all together.
chris89yj is offline
post #2 of 8 Old 05-23-2013, 02:03 AM
JSchuricht's Avatar
The first issue I see is there is no in tank pump, only the one on the frame. It sounds like just a minor electrical issue. Check the basics; fuse, relay, rollover switch and the wires.
JSchuricht is offline
post #3 of 8 Old 05-23-2013, 04:54 AM
Sounds like the inertia switch behind the passenger kicker panel. You should be able to feel behind there, and there is a button that will push down if that's what's wrong.
1996 F350 CCLB, 4x4, 4:10, auto, tymar intake, 3" dp, 4" SS exhaust, gutless kitty, gauges, ts 6 pos, ebpv delete, ww2.
Trucknt is offline
post #4 of 8 Old 05-23-2013, 12:52 PM Thread Starter
It is not the crash switch
post #5 of 8 Old 05-23-2013, 01:39 PM Thread Starter
ok after talking with the cheif the basic were checked. the problem is due to a plug on a harness at the back of the engine block on the top side of the motor under the fire wall. that was the discription that i got.
post #6 of 8 Old 05-23-2013, 06:29 PM
nathan's Avatar
Can you post a picture of the connector. The description isn't helping much.
[/SIGPIC]
99 superduty crew cab 4x4
95 f250 4x4
91 ID IBronco Centurion (rough) but only 895 miles
86 IDI f250 4x4 (just bought)
2000 custom bike I built
nathan is offline
post #7 of 8 Old 06-15-2013, 09:38 PM Thread Starter
ok so I (and a buddy) figure out its the harness plug for the fuel cut off cylinoid. its just the plug. i need the end that plugs into the oil pressure contaner on the front of the motor. i can slice one in if anyone has one with about 3" wire on it. gona check junk yards when i have time.
post #8 of 8 Old 06-21-2013, 09:45 PM
TNFireman's Avatar
Being a fire truck....who knows what was tapped into when it was outfitted with the grass rig.
Does it have an auto charge? does it have a diesel fire pump possibly tied into the factory fuel tank? before or after the pump ive seen both.
were there any emergency equiptment wiring or outfitter wiring run down the frame rail near the factory harness that could be hiding or causing chaffing against the frame? these trucks have tons of wires to run anything from generator starters, booster reels, scene lighting, 50,000 different emergency lights. in cab controlled deck guns and bumper monitors. and my experience is some companies that outfit these trucks do better then others with wiring. some are over complicated and cause issues. some are simple and keep on working.
we had a truck that gave us trouble everytime you turned the emergency lights on the factory horn would honk and the dome light would flash intermittantly on a 550 chassis.
on edit i see you found your problem
on a 7.3PSD ive never heard of a FSS. i thought that was a mechanical motor thing. but i can see an oil pressure switch if it looses pressure it kills the pump, but again that sounds like a mechanical motor set up as a PSD computer monitors that stuff and it wont run without oil anyways.
but im not up on all the 7.3 stuff as much as i need to be compared to the newer motors. its been a while since ive had one besides the IDIT
94 F350 xlt, 4x4, 7.3 idi turbo cc/lb 36" maxis buck shots getting paint!!!
06 F2504x4 PSD KR, H11studs,175/75's from warren ordered!!,idp tuned ficm egr delete IDP Custom tunes mbrp 5" edge Insight cts with pyro and isspro fuel pressure gauge, air dog 165 to put on and turbo to order RCD 68mm or powermax modded
IAFF Member International Association of Fire Fighters
TNFireman is offline
