1995 7.3 major oil loss! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-21-2013, 09:46 PM Thread Starter
Exclamation 1995 7.3 major oil loss!
I was drivin my 95 7.3 today and had no issues. Parked it and came back about 30 minutes later and found about 1 gallon of oil on the ground ive been told that its the rear main engine seal but ive also heard thats highly unlikely. Any ideas as to where this oil could be comin from?????
GRIZZLYDIESEL is offline
post #2 of 3 Old 05-22-2013, 05:31 AM
Several things it can be, look on top of the engine under the turbo, and see if there's oil there. It could be your turbo pedestal o rings, ebpv, high pressure oil lines, fuel pump, or the hpop. If you search the forums, there are a lot of discussions on all the above. Good luck, oil leaks are never fun, I just cleaned my driveway after having to fix my turbo pedestal o rings a couple weeks ago.
1996 F350 CCLB, 4x4, 4:10, auto, tymar intake, 3" dp, 4" SS exhaust, gutless kitty, gauges, ts 6 pos, ebpv delete, ww2.
Trucknt is offline
post #3 of 3 Old 05-22-2013, 08:52 AM
More than likely the plug on the back of the HPOP has blown an o-ring. Its is extremely common and you loose oil very fast. It is a very easy fix if that is the problem.
calfarley1 is offline
