scan tool
i was running down the highway and just came off of passing gear and started loosing power and pulled over. it idled very rough and after i pulled off the highway onto the outer road it died. when i try to restart it it fires very roughly but will not run. fuel bowl is filling, turbo wheel is turning. i have taken out the bb mod and taken off the 10k mod. i returned the pcm back to stock and pulled the chip. any ideas?
the cam sensor recall has also been done.
does anyone in the kc area have a scan turn, not just a code reader i could use.....or allow me to test my engine with their icp sensor to narrow down the possibilities?
thank you
