97 7.3 l died and won't restart - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-02-2008, 06:47 AM Thread Starter
My F250 died on my wife the other day and would not restart.Had it towed home.Fuel filter bowl was empty.After cranking on engine bowl filled up 1/2 way.New fuel filter.Oil full.Is pump gone?Nearest shop is 20 miles away.Hate to pay to have it towed again.Any suggestions?Need truck for work.
whitechief is offline
post #2 of 4 Old 03-02-2008, 06:57 AM
SMKSTAX's Avatar
I am by no means a tech but it sounds like a fuel pump to me. Your fuel bowl should be full to the top.
RICK
97 F350 CREW CAB 4x4, 7.3 TURBO DIESEL, DIY INTAKE , TW TUNES
GRAND ROCK POWERFLOW STACK KIT W/5" MITRES
3.55 REARS, 3" DOWNPIPE, FPR SHIMMED WITH GAUGE
SMKSTAX is offline
post #3 of 4 Old 03-02-2008, 07:04 AM Thread Starter
That was my first thought too.Also no smoke when cranking.Usually puffs white smoke when trying to start.
post #4 of 4 Old 03-02-2008, 07:15 AM
How much fuel on the gauge? If it is 1/4 or less it may have just pulled air into system. Fuel pump is not the strongest feature on the 7.3. Mine will suck air if going uphill (nose up) with 1/4 tank of fuel or less. I put an electric just in front of the fuel tanks and it helps.
Diesel Monkey is offline
