'07 Stranded in Bagdad - Ford Powerstroke Diesel Forum
post #1 of 14 Old 03-02-2008, 04:08 AM Thread Starter
Ryan Rønning's Avatar
Quoted: 6 Post(s)
We need to know what the TBC fault code on the dash is. Truck turns over but will not start. We are in a bad situation right now. Please help.
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, TW tunes, 4" DP, Napa Intake, coolant filter, 140cc Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #2 of 14 Old 03-02-2008, 04:30 AM
mdiesel's Avatar
bump
Mat
2006 F250 6.0L
mac intake
ZooDad Mod
Accufab polished Elbow
sct innovative tunes
Cat delete with cool duals
14.069@95.62MPH
someday
water/meth
headstuds
MAP - Mid-Atlanic Powerstrokers member
mdiesel is offline
post #3 of 14 Old 03-02-2008, 04:51 AM Thread Starter
Quoted: 6 Post(s)
Figured it out. It is the Cam Position sensor. Now I just need a part# if anyone can help me out.
post #4 of 14 Old 03-02-2008, 04:54 AM
mdkallam130's Avatar
Send a message via AIM to mdkallam130
here is the part number from autozone SU2159
2002 F250 Crew Cab 4x4 7.3
35x12.50x17 on a set of 2005 F250 Wheels
S&B air intake customized
4"turbo back straight pipe with a 5" tip,
gauges
DP TUNER - on its way
wish list.
5"turnout stacks,injectors,bigger turbo, bigger hpop, fass system, Built Transmission
"I'D RATHER BE JUDGED BY 12 THAN CARRIED BY 6"
mdkallam130 is offline
post #5 of 14 Old 03-02-2008, 04:58 AM Thread Starter
Quoted: 6 Post(s)
I dont know if I can get that through the ARMY, any chance for a ford or International part #. The truck is an Iraqi Army 06 or 07 6.0!
post #6 of 14 Old 03-02-2008, 05:18 AM
not real sure man...the part # i give you probably wouldnt work anyway ..when you said cps i figured it had to be a 7.3...
but heres a bump for you..good luck
gauges
wish list.
post #7 of 14 Old 03-02-2008, 05:25 AM Thread Starter
Quoted: 6 Post(s)
I am having trouble finding it. I know it exists but even Motercraft.com is killing me.
post #8 of 14 Old 03-02-2008, 05:36 AM
Slacker
Evil Eye's Avatar
Quoted: 208 Post(s)
Feedback Score: 4 reviews
CPS on a 6.0L? I haven't heard of them going bad... I'm having trouble finding the part number as well.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #9 of 14 Old 03-02-2008, 06:02 AM Thread Starter
Quoted: 6 Post(s)
Bump Bump Bump
post #10 of 14 Old 03-02-2008, 06:13 AM
Marine Raiders>Seals
najaf4life's Avatar
I am looking and trying to help but can't find it any where...
RYAN
03 Excursion 6.0L
BPD,WPE & other odds and ends
najaf4life is offline
